wouxun software problem - tool15 An unsupported operation was attempted
Discussion in 'Amateur Radio Software' started by MOTIN, Mar 15, 2015.
  1. MOTIN
    MOTIN QRZ Member
    gd days
    if you are having this error on wouxun software
    An unsupported operation was attempted or tool15 with same error
    then you have some problem in :
    in the install
    here is what you need to do to fix the problem
    Pls put the two files into c:\windows\SysWOW64
    Press Start/Run and type - regsvr32 c:\windows\SysWOW64\MSCOMCT2.OCX
    Press Start/Run and type - regsvr32 c:\windows\SysWOW64\Msflxgrd.ocx
    After you should be ok with the error you had before
    Thanks to the support of wouxun who helped me solve this issue
    link for the files for you
    https://onedrive.live.com/redir?res...12&authkey=!AAv6GGa7ID2IYm4&ithint=folder,rar
    gd luck pls update if helped you solve the problem
    motin
  2. ZL1VSF
    ZL1VSF Ham Member QRZ Page
    While trying to install software to communicate with my Wouxun KG-UV8D, I had this and may more kinds of error messages. I tried many different drivers and actual programs before eventually getting one version from powerwerx.com to work. It was probably the most problematic software I have ever tried, on this PC, to get working... However, persistence did pay off...
    The two drivers you mentioned above - MSCOMCT2.OCX & Msflxgrd.ocx, are very common Microsoft drivers and many times they are already in the "System" folders. They both were in mine way before I even got my KG-UV8D. I just checked some older system backup images dating back a couple years and they are in them. It could be that a later version is required though and the software may not update them correctly... As I said,, this was very a problematic installation...
    Then again, many of these radio comms programs have had similar problems...
  3. K6LCS
    K6LCS XML Subscriber QRZ Page
    >> ...Then again, many of these radio comms programs have had similar problems...
    That is what makes the programs from RT Systems so much more pleasant to use. Truly "plug and program." Have a problem? You can chat online or actually call them during the week. No messing with cables of unknown origin ...
  4. WA7ARZ
    WA7ARZ Ham Member QRZ Page
    Hello,
    I tried to download the 2 files but how do you save them to the SysWOW64 ? It only lets me save them to the desktop.
    I have wasted over 6 hours on this garbage from Powerwerx / Wouxun. I could have manually entered everything by now.
    Mike KA9WAT
