ad: vanity
Unverified Seller Wouxun KG-UV9D(E) Plus
Discussion in 'Ham Radio Gear For Sale' started by K7HPY, Jun 15, 2019.
  1. K7HPY
    K7HPY Ham Member QRZ Page
    Wouxun KG-UV9D(E) Plus $155
    7 Band - Twin Bands TX – Seven Bands RX
    Like NEW in Excellent Working Order
    Original Price: $199.99 plus $19.99 High Gain Antenna from PowerWerx
    Includes: Transceiver, AC Adapter Charger, Manual, Box, Standard & High Gain Antenna
    • Cross-band two-way nn Repeat function
    • Cross-band one-way Repeat function
    • Repeater function, user adjustable Hang Time from 0.1 to 0.5 seconds
    • Selectable Speaker Audio ON/OFF during Repeat function
    • RX Green LED flashes every 5 seconds, user selectable On/Off
    The KG-UV9D Plus is a compact, high-performance dual-band handheld amateur radio transceiver with large LCD color display providing up to 5 Watts of RF power on VHF and 4 Watts on UHF, along with high audio output (500 mW).
    The KG-UV9D features extended operating time (over 18 hours), thanks to the included long life 2000 mAh high capacity Li-ion battery pack. In addition the KG-UV9D Plus features Full Duplex operation to transmit at the same time you are receiving on to opposite band. A new color LCD screen displays everything you need to know and includes the IP55 water resistant rating. The KG-UV9D uses a new model Li-ion battery and drop in charger and is not interchangeable with previous Wouxun models. All Wouxun speaker mics, lapel mics and earpieces (KG-UV8D, KG-UV3D, KG-UV6X, DB-16X) are compatible with the new KG-UV9D Plus.
    Software programmable via the optional low cost USB programming cable or manually programmable via keypad.
    KG-UV9D Plus Model Features
    • Large backlit color LCD display
    • True simultaneous dual receive (V+V, U+U, V+U)
    • 999 memory channels
    • 2.5 KHz channel step for VHF Band
    • 7-Band receive frequency range: 76-108 (FM Radio), 108-136 (AM), 136-180 (FM), 230-250 (FM), 350-400 (FM), 400-512 (FM), 700-823 (FM)
    • Dual band transmit frequency range: VHF: 144-148 (FM), UHF: 420-450 (FM)
    • CTCSS/DCS Tones with User Defined Tone Capability
    • Standard SMA antenna connector
    • New heavy duty belt clip
    • Includes Li-Ion battery and Desk Charger
    • Free Programming Software download, requires optional (WXUSB) red colored programming cable
    FCC Approval
    The KG-UV9D Plus is certified for Amateur Radio use with a Part 97 approval.
    • True Dual band Receive (VHF/UHF, VHF/VHF, UHF/UHF)
    • 8-Character Alpha-Numeric, Backlit Color LCD Display
    • Selectable high/low power settings (VHF: 5/2/1W) (UHF: 4/2/1W)
    • Includes extended life 2000 mAh high capacity li-ion battery as standard
    • Includes intelligent desktop 3-4 hour rapid charger
    • Loud speaker audio output (500 mW)
    • Bright flashlight illumination function
    • Meets IP55 waterproof rating
    • English female voice prompts enable non-sighted operation (can be turned off)
    • 999 channels memories (shared)
    • VOX Function
    • Digital FM radio (76-108MHz) with automatic tuning and storing, radio frequency display, 18 FM memories in 2 banks
    • Wide/narrow bandwidth selection (25 or 12.5 kHz)
    • Power on message: Displays battery voltage or color logo
    • Windows PC programmable, free software available for download. Optional low cost cable (SKU: WXUSB) required.
    • Radio to radio cloning with optional cable (SKU: WXCLN)
    • Same channel: VHF TX & UHF RX or UHF TX & VHF RX available
    • 50 CTCSS/105 DCS tones with split tone capability
    • 16-Key DTMF encoding
    • User defined CTCSS tone capability
    • Stopwatch function
    • SOS function
    • Low-voltage voice prompt
    • Busy channel lockout
    • Selectable TX timer (from 15 to 600 seconds)
    • Selectable step sizes of 2.5, 5, 6.25, 10, 12.5, 25 kHz
    • Multiple scan modes including priority scan
    • Keypad lock (auto or manual)
    • Programmable by computer or front keypad
    • High contrast white backlit keypad.
    Frequency Receive Range
    76-108 (FM Radio)
    108-136 (AM)
    136-180 (FM)
    230-250 (FM)
    350-400 (FM)
    400-512 (FM)
    700-823 (FM)
    Frequency Transmit Range
    144-148 (FM)
    420-450 (FM)
    Memory Channels
    999 channels (shared)
    Operating Voltage
    7.4 VDC
    Operating Temperature
    -22°F to 140°F (-30°C to +60°C)
    Dimensions (W x H x D)
    2.4 x 4.9 x 1.3 inches (62 x 124.5 x 34mm) (without antenna)
    Weight
    8.9 ounces (253 grams)
    RF Carrier Power
    VHF: 5/2/1W, UHF: 4/2/1W
    Audio Output Power
    500mW maximum
    Waterproof Rating
    Original Price $199.9 plus $19.99 High Gain Antenna
    Contact: K7HPY@todddaune.ch
    PayPal Only
    USPS Priority Shipping Included.
  2. QRZ
    Important Rules
    Have you read the Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Got questons? Contact our moderation team here...
    All Sellers Must Be Verified As of July 1, 2019, only Verified Users are permitted to post in this forum.
