Windows 7 64bit USB to Serial
Discussion in 'Computers, Hardware, and Operating Systems' started by KC9FSH, Dec 20, 2009.
  1. KC9FSH
    KC9FSH Ham Member QRZ Page
    I am running Windows 7 64 bit Ultimate edition and tried to use my USB to Serial converters that I've used for the past few years to control my radio.
    I downloaded the latest Prolific drivers and installed them yet the USB to Serial converters still come up that Windows Failed to Install Device or something along those lines.
    When I go into device manager the converter does appear in the list but it has a yellow exclamation mark next to it, in the device properties the error message is
    "This device is not configured correctly. (Code 1)
    The name is already in use as either a service name or a service display name."
    Everything I've tried still hasn't helped. Does anyone have any ideas on what could be causing this? If I can't get it working then what does everyone else use for usb to serial adapters?
  2. WD0MYM
    WD0MYM Ham Member QRZ Page
    I can't help you with the problem your having with your current adapter. I'm not smart enough!! I have tried 2 different adapters. The first one is from Keyspan model USA 19HS. It works perfectly. That was my backup adapter I used with the YAESU CT62 cable. Notice the caps in Yaesu. I have seen some cables possibly being sold as a Yaesu brand cable. The Keyspan adapter is fairly popular, I read about folks having good luck with it.
    The other cable in use daily is the one sold by RT Systems. I don't know if they make a model for every radio, but it eliminates purchasing the adapter, as it already has the USB end on it. It is priced right. As of right now, it is the cable I prefer for my setup. I have a very small issue with the RT: the USB end is pretty wide, which means I have to plug it into the end of the computer that has one USB port on it. I can't plug it into the other side where I have 2 USB ports right next to eachother. I can plug it in, but it will block the other opening for the USB port because of its size.
    My equipment is as follows: Brand new HP laptop with Windows 7 64 bit and a Yaesu 857D. I am using HRD and DM780 Version 5. I also use the Signalink USB along with the cat cable from RT systems. I connect at the highest speed available, 38,400 and run the refresh rate at a 100 miliseconds which is the fastest that is available in HRD.
    I hope this helps. Both cables work flawlessly and I am sure other adapters will work well.
    WD0MYM
    73 Jon
  3. VA3CSS
    VA3CSS Ham Member QRZ Page
    Double-check that you got the correct one. I have a Prolific-manufactured USB to Serial adapter working just fine in Vista 64-bit, which uses the same driver as Windows 7 64-bit.
  4. YU2MMA
    YU2MMA Ham Member QRZ Page
    You can isntall virtual machine and install Wndows XP on it. Than you can try like this to connect your rig. Friend of mine use Ham Radio Deluxe, and his server is on virual machie, and he is using remote connection on installed HRD on Win 7 to Win XP
  5. N2RJ
    N2RJ XML Subscriber QRZ Page
    I have a PL2302 USB to serial working as well as a keyspan USB to serial working. This is in Win 7 x64 home premium.
    Which adapter do you have?
    The VM thing is overkill, IMO. YOu shouldn't have to fire up a vm every time you want to play radio... might as well just downgrade back to XP!
  6. KD0DKI
    KD0DKI Ham Member QRZ Page
    If the processor supports virtualization.
    XP mode is not virtual . PC.
    BTW W7Pro is installing on my new rig, asus M4A78T-E, 6 Gig of DDR3, AMD Phenom II X3 705e at 2.5ghz. Santa was very good to me this year!
    Lots of configuration of W7Pro to do to get it to work as I want it but it shouldn't be to bad.
  7. KC9FSH
    I tried the Vista drivers along with the ones that Prolific said were for Windows 7. I believe the issue is a conflict with something on my computer, but I can't figure it out.
    I'm normally pretty good at troubleshooting what is wrong with the computer, but I think I'll have to break down and bring it over to one of my buddie's and have him look at it.
  8. KA7O
    KA7O Ham Member QRZ Page
    Connect all USB to serial adapters you've ever installed.
    In Device Manager - DELETE them all (have to connect them first so they show up! Easy to find the borked ones with the yellow warning. Delete all of them anyway.)
    Shut down the PC (power off - No sleep, hibernate or 'stand-by' - must be a real power off "cold stop". May have to modify your start button properties to get this)
    Disconnect all USB to serial adapters
    Turn PC back on
    Re-install drivers
    Re-connect adapters
    good luck!
  9. KC9FSH
    I just tried that and I'm still getting the following error when I view the USB to Serial in device manager.
    The motherboard I'm running is a Asus M3A78-EM.
  10. N2RJ
    I had this same problem. I recently got a new HP e9280t (Core i7) with Win 7 x64, connected my USB to serial adapter and it didn't work.
    I then downloaded the driver from here.
    This driver works well with Win 7. Just make sure your adapter is disconnected when you do the install. If it fails on one USB port, try another port and it will pick up the driver. You can then switch back and it will work.
    Let me know how it works out.
