ad: Winterfest-1
Why I need a HF Amplifier
Discussion in 'Ham Radio Discussions' started by N8FVJ, May 16, 2019.
  1. W4NNF
    W4NNF XML Subscriber QRZ Page
    Facebook? Huh! Like it says on the sticker, "I'm good on QRZ!" We're all mad here! :D
    W2AI likes this.
  2. KY5U
    KY5U Subscriber QRZ Page
    A well crafted ham station has a good antenna and needs only 100w (or less)
    A restricted station uses power to overcome a crappy antenna.
    Here in the south, 80M is noisy in the summer with lightning and weather. Often the noise is S9 to 10 over. If you want to talk, the answer is a signal better than the noise. A good antenna may not be enough.
    W4WTS likes this.
  3. K9STH
    5U:
    I sincerely disagree with your "well crafted" comment. 100-watts "may be" adequate for many operators. However, with higher power, the band generally "opens" some time before and "closes" some time after when compared with the lower powered stations.
    I do agree that one should get the best antenna system possible before going to higher power. Then, going higher in power is definitely an option.
    AA5CT likes this.
  4. K6LPM
    K6LPM Ham Member QRZ Page
    [QUOTE="K9STH, post: 5073937, member: 195296
    Aone should get the best antenna system possible before going to higher power. Then, going higher in power is definitely an option.
    [/QUOTE]
    Then after that get a big multi-element Cubical Quad or a maybe a stack of The big Step IR.
    Of course you can always continue to go bigger with a huge Sterba Curtain!
    I can just imagine not only opening and closing the band , but making your own propagation at will!
    WZ7U likes this.
  5. N3PM
    N3PM Ham Member QRZ Page
    Mike N3PM
  6. WA9SVD
    WA9SVD Ham Member QRZ Page
    Hmmm. QRP just doesn't cut it. Change to 100 Watts... still not enough power... go to 1500 watts, the legal limit... there are STILL stations that don't hear me. Switch to...??? When does it end? YMMV.
  7. W2AI
    W2AI QRZ Lifetime Member #240 Platinum Subscriber Life Member QRZ Page
    Yup, I'm good on QRZ--for life!! :D
  8. W2AI
    SHHHHHH.....only a hobby. Antenna is everything in radio communications.
  9. WF4W
    WF4W Premium Subscriber QRZ Page
    antenna is everything, yes, but is often constrained by space, finances, HOA, or wife. Built the best antenna that YOU can and then add power. That's what i did.
    WD4IGX, W4WTS and W2AI like this.
  10. WA9SVD
    I agree. Each $1.00 spent on antenna improvement often costs at least $5-$10.00 in amp co$t. But there IS a limit to antennas. There is also a limit to (legal) power, although SOME hams don't seem to abide by the rules, and run well in excess of the legal limit.:(:mad:
    W2AI and WF4W like this.
