What was your *very* first antenna starting out?
Discussion in 'Survey Center' started by AD7N, Jan 12, 2011.
  1. ortable VHF/UHF antenna: HT "rubber duckie" short antenna
    88 vote(s)
    18.5%
  2. Portable VHF/UHF antenna: larger detached antenna (rolled up j-pole, 5/8 whip, Arrow II Yagi, etc)
    33 vote(s)
    6.9%
  3. Base VHF/UHF station: J-pole antenna/ SlimJim antenna or varient
    30 vote(s)
    6.3%
  4. Base VHF/UHF station: commercial vertical
    23 vote(s)
    4.8%
  5. Base VHF/UHF station: other (please list below!)
    15 vote(s)
    3.2%
  6. HF Station: G5RV antenna
    36 vote(s)
    7.6%
  7. HF Station: Dipole of some kind
    208 vote(s)
    43.7%
  8. HF Station: Loop of some kind
    8 vote(s)
    1.7%
  9. HF Station: other (please list below!)
    91 vote(s)
    19.1%
Multiple votes are allowed.
  1. AD7N
    AD7N Ham Member QRZ Page
    What was your first antenna starting out?
  2. AJ4JQ
    AJ4JQ Ham Member QRZ Page
    Mine was (and still is) a ladderline-fed dipole strung between two trees at about 70 feet. It's about 110 ft. long. It works amazingly well, and I've never had any problems with it. I highly recommend it to anyone considering a new antenna.
    73, Frances / AJ4JQ
  3. W5MBB
    W5MBB Ham Member QRZ Page
    my 100 foot long extention cord. I used it for a few days until i went down and got me some wire to build a loop
  4. AD7N
    Very first true HF antenna was a fan dipole for 40m/20m. Before that, I had an SWL antenna which I took a coil of wire, ran it around the 4 corners of the ceiling and left the rest of the coil dangling in random fashion. Worked okay for 80m receive!
  5. K9ASE
    K9ASE XML Subscriber QRZ Page
    Base VHF/UHF other. I used my old 102" steel whip CB Antenna hooked it up to my radio via a piece of coax from my CB days. I then zipped tied it to the lilac bush outside the shack.:eek: I then Used my Radio Shack Ham/CB SWR meter and began trimming. It worked great for awhile until I could afford a real antenna and the weather let me get on the roof
  6. W0UZR
    W0UZR Ham Member QRZ Page
    A ground plane
  7. KG4ZAR
    KG4ZAR Ham Member QRZ Page
    My first ham antenna was a welding rod ground plane. I've since made antennas from all sorts of salvaged junk. Mostly odd stuff like weed-eater shaft tubing and other "off-the-wall"junk.
  8. NY3V
    NY3V Ham Member QRZ Page
    Mine was a 40 meter folded dipole only about 15 feet above the ground, running east to west on a 40 ft tree in front of the house on the street in the west to about 30 ft up the telco pole on the east alley.
    Running 50 watts AM input from a WRL Globe Scout xmtr & Hallicrafters SX100 rcvr from NW Illinois. I talked as far as Imperial Valley, CA around 1957. :)
  9. KB0TT
    KB0TT Premium Subscriber QRZ Page
    75 meter Dipole
    Made out of copper-weld stuff .
    A balun fed with 9913 coax .
    It worked fine on 40 meters where I cut my CW teeth ( as a NOVICE ) !
    We do not have a Novice ( class beginner ) license anymore , that is too bad .
    Cool. :cool:
    J.
  10. W0BTU
    W0BTU Ham Member QRZ Page
    Before we knew any better, a random-length end-fed wire, using the house wiring as the "ground".
