ad: SOTA-1
What is the best material to use for enclosing a porch (exterior walls)?
Discussion in 'ex-Rag Chew Central' started by KA8RAW, Jun 30, 2011.
  1. KA8RAW
    KA8RAW Ham Member QRZ Page
    I want to enclose a porch, but I am unsure of the proper material to use.
    I need something 1/2" or 7/16" thick, and would like 4'x8' sheets preferably.
    I was looking at a 50 year siding that is used in the construction of sheds, and sells for about $25 per sheet,
    but I would also like to get other ideas. The material will be used as the exterior walls of the porch, so something
    that has good water resistance is what I am looking for.
    Low cost, easy installation are important.
    I'll bet there are many hams that are contractors, or have construction experience, so please throw some ideas at me.
  2. KJ4CCH
    KJ4CCH Ham Member QRZ Page
    Hey,
    You could do a screen enclosure. It would be cheaper! my Grandmother years ago, had a porch, and she had like a metal frame around it. It was like a shed, much like what your talking about.But it gets HOT in there with out a fan.
  3. N5YPJ
    N5YPJ QRZ Moderator QRZ Page
    I like T-111 a lot but I'm sure there's a better substitute today. What do you want to use the porch for after it is enclosed?
  4. K8ERV
    K8ERV Ham Member QRZ Page
    Maybe you could check with some neighbors who have done this and get their experiences.
    TOM K8ERV Montrose Colo
  5. N3HQN
    N3HQN Ham Member QRZ Page
    If you want to close it in as though it were going to be a room. No screens that type of thing. Look into the "Hardie" panel products. Great stuff. Long lasting. There are pros and cons to it but, I have used it for customers in the past and never had a complaint. I guess you could use it even if you were going to have screened in windows. Duh! Oh by the way work is slow here.... need a price on the job?
  6. KD8HLY
    KD8HLY Ham Member QRZ Page
    Considering the place where you live,, you might want to put up something
    Bullitproof ! Does "Kevlar" come in 4x8 sheets ?
    Toledo has had 6 shootings in a five day period,, Like living in the old west, only without
    the horses !
    73 KD8HLY George
  7. KA9VQF
    KA9VQF Ham Member QRZ Page
    You could use ½” CDX and paint it or put siding on it.
    I used to build a few sheds for folks in a years time and used an embossed plywood that looked a lot like the old time clapboard buildings.
    With a coat of paint it will last for many years. Most of the shed kits you can get from the big box stores use blandex chip board. If you keep that stuff painted it can last for a long time too.
    Be sure to properly stud your porch. ½ inch plywood is rated for 24” span but I always invest the additional 2X4’s to fill the space. Set your 2X4’s at 16” on center. You’ll thank yourself for doing the job right later.
    You might also think about investing in 2” Styrofoam insulation. My shed out back has only ½” Styrofoam for insulation and it helps keep things cool in the summer and warm in the winter.
    I have a piece of 1X6 lumber with a little frame and some expanded metal over it all. There are two sockets with 100 watt incandescent light bulbs in it. when placed on the floor will warm it up to where you don’t need gloves when your working on things. When I know I’m going to be out there working on things in the winter I’ll turn the lights on the night before and just leave them on.
    It really makes a difference.
  8. KA8RAW
    Just to relax and enjoy.
    We just had 6 more over the holiday weekend, wonder how much Kevlar costs?
    HQN, I am considering Hardie Panels, they seem quite nice.
    VQF, If I could find an exact match for the siding on the house, I would probably go that route.
  9. W2BBQ
    W2BBQ Ham Member QRZ Page
    Hi RAW, Mercy....typical conflicting-unreasonable request.
    Your title says "best" then you also want it for "low cost." Those two never go together. Pick one but ya can't have both.
    Your porch exterior should also match the construction or at least the looks of the rest of the house.....or it won't look right.
    What is your house sided with? Put same on porch if possible.
  10. N7WR
    N7WR Subscriber QRZ Page
    When I enclosed both our front and back porches I used CDX and then put vinyl siding over that, painted to match the rest of the house. Are you putting in some windows? And when you do insulation and the inside walls put some electrical outlets in--always a good thing to have.
ad: NI4L-2
