ad: Schulman-1
what antenna would you build?Given
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KA4DSK, Apr 8, 2012.
ad: K3QNTad-1
  1. KA4DSK
    KA4DSK Ham Member QRZ Page
    Given option which antenna would be best for 40/20/17/15/and10
    an ocfd or a fan dipole i have the materials and space to make
    both but can only place about 30 feet above ground.
    feed line from radio to antenna would be about 60 feet.
    THANKS TO ALL THAT RESPOND.Frank ka4dsk
  2. AD4J
    AD4J Ham Member QRZ Page
    Of the two options you mention, I'd go for the fan dipole because it is less likely to have common mode current problems leading to RFI and noise pickup issues. However, it will take some fiddling to get the lengths right for resonance on all those bands, because the conductors interact, particularly on the higher bands.
    My preference is for a third option - a 40 meter dipole feed with balanced line, using a balun and tuner. That has been my main antenna for several years now and I've been very successful with it. Combined with raised quarter wave radials for 80 & 160 meters, I also use it as a top loaded vertical on those bands. This antenna has produced contacts on all 11 bands from 160 through 6 meters for me. The downside is that there are some deep nulls in the azimuth patterns on the bands above 20 meters, but even a half wave dipole has significant nulls off the ends.
    Jim
  3. KG4NEL
    KG4NEL Ham Member QRZ Page
    That would be my choice as well.
    Or, if you have the supports for a horizontal loop, you could build it as a full-size loop for the lowest band you're interested in. Feed it the same way as you would a doublet, to a good antenna tuner.
    http://srgproperties.inetusanow.net/files_custom/9467_2192.pdf
  4. KB5UBI
    KB5UBI Ham Member QRZ Page
    How much space do you have? I also vote for center feed with the balanced line. Put as much wire up as you can, 66' or more if you can and feed it with ladder line all the way to the shack through a 1:1 current balun at the tuner. You can trim the feeder if necessary.
  5. KB4QAA
    Neither.
    I would put up a Center fed dipole fed with balanced line.
    A fan dipole is too fussy for me to fiddle with. OCF? Pulleease.
  6. N0SYA
    N0SYA Ham Member QRZ Page
    Fill the available length with a single wire dipole, feed it with coax, add some ferrites to both ends of the coax, and force feed all bands via a transmatch.
  7. KC8QVO
    KC8QVO Ham Member QRZ Page
    Isn't a balanced antenna (equal lengths on either side of the feedline) fed with balanced line to a tuner called a Doublet?
    I thought a dipole only referred to a resonant 1/2 wave length antenna built for one band (or, a portion of one band).
  8. N5YPJ
    N5YPJ QRZ Moderator QRZ Page
    Center fed doublet 66 ft long fed with ladder line. I like fan dipoles but my experience has been that when one adds unrelated harmonic bands to the antenna "the fun begins" in question to getting all of the elements properly adjusted where we are "one big happy family". As long as it is 40-20-10 the adjustment is a lot easier.
  9. KA4DSK
    Hi Jim will give your option a try,i have about 75 feet of clear space between trees that i will be
    able to use for end supports .wiil have to get some ladder line and balum<not sure 1/4 or 1/1 coax coil type>
    will need to use coax in to house as i need to enter at ground level and come up from basement to first floor
    house is stone and i don,t to chop holes in the thick walls. the worst thing i could find next is my trees are not located for best sig to the week station you need HI HI frank
  10. KB4QAA
    1. Yes, sometimes. Tuning arrangements have no bearing on antenna naming conventions or definitions.
    2. No.
