WHAT??? ANOTHER SB-220????!!!!!!!!!!!!!
Discussion in 'Amateur Radio Amplifiers' started by WA6MHZ, Jul 31, 2017.
  1. AF6LJ
    AF6LJ Ham Member QRZ Page
    You are right it is a voltage doubler..
    Helps to have contact lens in
  2. WA7PRC
    WA7PRC Ham Member QRZ Page
    They just used replaceable fuses, so they could be selected appropriately based on the source voltage. The way you had the SB-220 breakers wired was correct ONLY when operating on 240V.
    !!!!!!!!!!!! <-- matching exclamation marks, for emotional effect.
  3. KV6O
    KV6O Ham Member QRZ Page
    :p
    WA7PRC likes this.
  4. WA7PRC
    I neglected to add emphasis using certain words in ALL CAPS. :p
  5. AF6LJ
    You guys are going to make me do it, aren't you??
    OKAY FINE Tomorrow I will sit down with highlighters and attempt to prove the as wired primary circuit is not only safe but will disconnect power when the breaker trips.
    :cool:
  6. WA6MHZ
    WA6MHZ Subscriber QRZ Page
    I agree with tne newer SB-1000 wiring, which uses 2 primaries and a jumper block just like the SB-220. The only difference is there is NO SSB/CW switching.
    AF6LJ likes this.
  7. WA6MHZ
    I gotta an original SB-221 manual at the HRO Swapmeet today for $5!!!
    AF6LJ likes this.
  8. AF6LJ
    That was a good deal. :)
  9. WA6MHZ
    I also got about 15 4CX250s with some chimneys and sockets.
    SO now I am thinking about a 2 meter KILOWATT!!!
    AF6LJ likes this.
  10. AF6LJ
    We need to do that.
