Weather Satellite Script Help (Raspbian)
Discussion in 'Satellite and Space Communications' started by K3RLD, May 31, 2018.
  1. K3RLD
    K3RLD Ham Member QRZ Page
    The MSA decoder works great. Playing with gain seems to do nothing beneficial.
  2. KA2CZU
    KA2CZU XML Subscriber QRZ Page
    Roy,
    What was the final solution for the script issues that started this thread.
    Seems like I'm repeating history here as I got to run the "pipe into sox" command line
    and am hitting the same errors as you did.
  3. K3RLD
    The problem was that I was using RTL-SDR drivers that were different than the ones that sox was expection. What I ended up doing was wiping the SD card and starting the install from scratch, EXACTLY step by step as detail on that how-to website. Then it worked.
    I have no clue what the actually offending code/driver/library is, however. Only that it worked after starting over and following the instructions word for word.
  4. KA2CZU
    Dang, that’s how I got to where I am.
    Guess I will have to retrace my steps and see if I left anything out :(
    All the scripting looks good but right now I’ve got 1 decoded snow png file and then nothing else. So I thought things were at least “working” ... but since no other files generated, I guess not
  5. K3RLD
    if you enter the command line manually (not in script), what is the response?
  6. KA2CZU
    /home/pi/weather/predict/schedule_satellite.sh "NOAA 19" 137.1000
    /home/pi/weather/predict/schedule_satellite.sh "NOAA 18" 137.9125
    /home/pi/weather/predict/schedule_satellite.sh "NOAA 15" 137.6200
    pi@raspberrypi-rs:~/weather/predict $ /home/pi/weather/predict/schedule_satellite.sh "NOAA 19" 137.1000
    var2 1537127560NOAA1920180916-153812 27
    warning: commands will be executed using /bin/sh
    job 71 at Sun Sep 16 15:38:00 2018
    NOAA1920180916-171821 37
    job 72 at Sun Sep 16 17:18:00 2018
    pi@raspberrypi-rs:~/weather/predict $ /home/pi/weather/predict/schedule_satellite.sh "NOAA 18" 137.9125
    var2 1537136368NOAA1820180916-194642 41
    job 73 at Sun Sep 16 19:46:00 2018
    NOAA1820180916-212749 25
    job 74 at Sun Sep 16 21:27:00 2018
    pi@raspberrypi-rs:~/weather/predict $ /home/pi/weather/predict/schedule_satellite.sh "NOAA 15" 137.6200
    var2 1537135497NOAA1520180916-175141 20
    job 75 at Sun Sep 16 17:51:00 2018
    NOAA1520180916-193011 51
    job 76 at Sun Sep 16 19:30:00 2018
  7. KA2CZU
    ok I'm guessing I'm near the root of the issue:
    pi@raspberrypi-rs:~/weather/predict $ /home/pi/weather/predict/receive_and_process_satellite.sh "NOAA 18" 137.9125 /home/pi/weather/NOAA1820180916-212749 /home/pi/weather/predict/weather.tle 1537147669 932
    Found 1 device(s):
    0: Realtek, RTL2838UHIDIR, SN: 00000001
    Using device 0: Generic RTL2832U OEM
    Kernel driver is active, or device is claimed by second instance of librtlsdr.
    In the first case, please either detach or blacklist the kernel module
    (dvb_usb_rtl28xxu), or enable automatic detaching at compile time.
    usb_claim_interface error -6
    Failed to open rtlsdr device #0.
    sox FAIL formats: can't open input `-': WAVE: RIFF header not found
  8. KA2CZU
    The instructions on that page for freeing up the rtl driver didn't work for me, I had to release the device by hand to run rtl_test successfully.
  9. K3RLD
    Did you create the modprobe file?
    I believe you need to "sudo reboot" after creating this file
  10. KA2CZU
    Yes created that and wouldnt any regular reboot be sufficient to pick this up?
    Have rebooted multiple times since (re) installing vnc to get that working
