W1AW to start on 6 meters again
Discussion in 'VHF/UHF - 50Mhz and Beyond' started by KC3JIN, Dec 6, 2017 at 2:07 PM.
  1. KC3JIN
    KC3JIN Ham Member QRZ Page
    WD4IGX likes this.
  2. WA8UEG
    Good to know, thanks. I live a bit closer then you and at a very high elevation in the Pocono's and can get them ground wave so I will be listening and sending reports.
  3. KB4QAA
    Very good news. I think it is important for them to encourage activity on the band.
    WD4IGX likes this.
  4. ND6M
    ND6M Ham Member QRZ Page
    Gee, aren't there already enuf beacons on 6?
  5. KL7AJ
  6. KB4QAA
    We aren't discussing that. In any case, the ARRL is not setting up a beacon. More people will be interested in hearing bulletins than simply hearing identifiers endlessly repeated.
    WD4IGX likes this.
  7. WA9ZZZ
    WA9ZZZ Premium Subscriber QRZ Page
    "Hop" usually refers to an ionospheric reflection. 6m is good for sporadic-E skip at certain times of the year. This tends to be around 1000-1200 miles for one hop. At 190 miles you are way too close for that.
    The sporadic-E skip can be interesting. 6m can suddenly open up with stations 1000 miles away being stronger than nearby stations. The band can be open for a while, then suddenly fade away.
    However, you are probably close enough to W1AW for some good ground wave or tropospheric propagation if you have a good antenna system (and if W1AW does). I'll let some others with more recent experience give you the details.
    N2EY likes this.
  8. K9STH
    K9STH Ham Member Staff Member QRZ Page
    Technically, there is no real "ground wave" signal on 6-meters. At 50 MHz, "ground wave" can be measured in feet / meters and not that many of those. "Ground wave" occurs on MF and, at times, up to the 80/75-meter band and has to be vertically polarized. What people call "ground wave" is really "line of sight" propagation and the radio horizon is right at 1/3rd longer than visual "line of sight".
    There are tropospheric conditions that extend the range and those conditions are subject to change at any time.
    N2EY, WD4IGX and ND6M like this.
  9. ND6M
    From the OP's link
    QUOTE:" another goal of the W1AW transmission on the Magic Band is to act as a beacon on 6 meters, especially from the Northeast US...."
  10. KB4QAA
    Yes, "Act as a beacon" to attract users to the band and modes. NOT to install an automated CW propagation beacon. Figurative action vs. literal technical installation.
    N2EY and WD4IGX like this.
