Vacuum Tube Direct Conversion Receiver / QRP transmitter projects
Discussion in 'Homebrew and Kit Projects' started by WB0RIO, Mar 20, 2012.
  1. WB0RIO
    WB0RIO Ham Member QRZ Page
    You all might be interested in this pair of vacuum tube hacks I put together this winter:
    http://www.solorb.com/elect/hamcirc/6U8directconv1/index.html The House Finch Direct Conversion Tube Receiver
    and
    http://www.solorb.com/elect/hamcirc/6U8qrptrans1/index.html The Little Chickadee 6U8A QRP Transmitter.
    Both projects are built around common 6U8A tubes, the receiver also has a 6BA6 RF amp and a 6C4 audio preamp.
    Before building the receiver, I searched the net for tube-based direct conversion receivers and did not find any
    previous work.
    73s
  2. AF6LJ
    Those are really nice.
    How well does the receiver work?
  3. WB0RIO
    I've copied CW, RTTY, WSPR and SSB signals with the receiver, and that's with a marginal 40 meter diople that sits on
    the shingles of my roof. As with most Direct Conversion designs, there's a tendency to pick up 60Hz hum, no AGC and reception
    of both sidebands, so don't expect it to be much better than a solid-state DC receiver. The audio filter is selective enough for
    decent CW reception.
    The VFO mechanics could be improved a lot, but it *is* a first generation prototype. It's basically a proof of concept design.
  4. AF6LJ
    Well that sounds good.
  5. KC8YLT
    KC8YLT Platinum Subscriber Platinum Subscriber QRZ Page
    I like how you constructed everything! Take your time youll get the bugs worked out. Looks like you have something to be proud of! KC8YLT.
  6. W1VT
    W1VT Ham Member QRZ Page
    That is a very good idea--electrical boxes are not only cheap, but a very good choice for direct conversion receivers in that they are very sturdy (less microphonics) and made of steel (magnetic shielding).
  7. K5UOS
    K5UOS Ham Member QRZ Page
    Homebrew tube receivers are rare. Thanks for showing your project.
    Have you measured/calculated the overall gain of the receiver?
    K5UOS
  8. AB9LZ
    AB9LZ Ham Member QRZ Page
    Mostly because folks build regens instead... which is in essence a direct conversion receiver with the added ability to detect AM signals. Since not too many folks do AM anymore, the direct conversion idea is a good one.... especially of one cheats a tad and uses a diode ring mixer (still use tubes for the osc and af amp).
    73 m/4
  9. WB0RIO
    I just did some quick tests, the results aren't super-accurate. And I don't claim to know how to do this test ;-)
    With a 15mV P-P input signal (50 ohm source) tuned in to produce the peak frequency
    of the audio filter, the output is 5V P-P into the 8 ohm speaker, the volume is set to about 2 out of 10.
    Dropping the input down to around 1mV P-P, the output is 4V P-P with the volume set to 10.
    That's as low as my signal generator goes and the scope (200Mhz Tek mainframe) mostly shows noise at 1mV.
  10. KO6WB
    I use to actually use a military surplus frequency meter to act as a receiver. It worked okay and it was a direct conversion reception type of receiver. It didn't have a tuned input circuit and I was sending the signal it generated into the antenna. This means I was radiating a signal, not much of one but it was there none the less. I don't remember it having hum problems and there were no microphonics. It worked but not as well as a dedicated receiver. Take a look at; http://www.freeinfosociety.com/media.php?id=5006.
    Gary
ad: IACantenna-1
