Uploading to LOTW from QRZ Logbook
Discussion in 'Logbook User Forum' started by KG5CIK, Feb 8, 2019.
  1. W1DQ
    There have been other LoTW postings leading to the below response.
    Nonetheless, I suspect that QRZ does not have your latest LoTW Certificate Container File (.p12):
    (Used for upload to LoTW). Importing your latest key below will replace any key QRZ has on file for AD7QC. The best I can offer is to retry setting up LoTW Access per: https://s3.amazonaws.com/files.qrz.com/static/qrz/lotw_cert_guide.pdf
    Otherwise, contact headquarters at: https://ssl.qrz.com/support
  2. AD7QC
    AD7QC XML Subscriber QRZ Page
    AD7QC: Thanks for the info
  3. KE0JRS
    KE0JRS XML Subscriber QRZ Page
    I have had the same issues as previous posters for several days. I tried updating the LOTW Certificate Container File with ZERO success.
    Now I cannot complete the update process as I receive errors from QRZ that my password does not match.
    I can log myself into LOTW without any issues using my correct password.
    I suspect that it must be a password authentication issue with QRZ.
    Sometimes I can successfully connect and transfer data into LOTW from QRZ while other times it errors out with password errors. I am definitely entering my password correctly.
    EDIT...I was able to get the LOTW Certificate updated. I was then able to successfully upload and download from LOTW. This problem has been intermittent in the past so I will continue to use the logbook and report back if I have issues.
