U.S. Congress: HR 4969--extending PRB-1 to private CC&Rs
Discussion in 'Ham Radio Discussions' started by WA7DU, Jun 27, 2014.
  1. KK4GGL
    KK4GGL XML Subscriber QRZ Page
    If you are allowed to plant trees, some 18+ ft palms could support all kinds of more or less hidden wire antennas.
  2. KC8VWM
    KC8VWM Ham Member QRZ Page
    Is there any reason why we can't install reasonable antennas, like OTARD is already allowed to do?
  3. KK4GGL
    Other than CCRs and HOA/COA rules? :rolleyes:
  4. KC8VWM
    Not following...
    My point is HOA's already have to accomodate the installation of outdoor antennas anyways.
    What difference does it make to HOA's if the antenna is an OTARD TV antenna on the roof, or if it's a 2m ham radio yagi antenna on the roof?
    Both antennas are almost identical in appearance anyways so why should HOA's even care if it's a ham radio or a tv antenna?
  5. N2EY
    Point is, when those trees get big, they'll be able to fall over onto the neighbor;s property. If the property is 30 feet wide, will the tree have to be cut down when it reaches 15 feet because it could fall onto the neighbor's yard?
    IOW, the "it might fall over" thing isn't valid.
    That's what the HR is all about: reasonable accomodation.
    The problem that's being addressed is the mindset of NO ANTENNAS NO MATTER WHAT NO WAY NO HOW NO EXCEPTIONS!!!!!
  6. NI7I
    NI7I Guest
    You wouid have to bring that up with the HOA. Silly question to put here.
  7. KC8VWM
    It's not a question, it's a talking point.
  8. WA7PRC
    WA7PRC Ham Member QRZ Page
    • "reasonable" ham antennas haven't been defined in HR4969. What is reasonable to one person is not reasonable to another.
    • OTARD allows satellite and terrestrial TV antennas, for public safety for potentially 330 million users. You want antenna(s) allowed for no more than 750K users who mostly don't do ANY public safety work.
    See above. Also, a satellite antenna would be pointed well above the horizon, and can be mounted close to earth w/o any deleterious effect. TV broadcasters typically run hundreds of kilowatts (ERP) of power, making a small yagi (short wavelength) at low AGL height effective.
    OTOH, hams have bands from 160m to well into the VHF-UHF spectrum and 1500W maximum. To be effective, antennas for those bands need to be larger (160m) and/or higher (VHF-up). A loop or vertical a few feet above ground on HF or a ground plane on VHF-up below the trees and houses blows.
  9. NI7I
    NI7I Guest
    In which case, it would be a talking point to bring up with the HOA. Unless, of course, you are trolling.
  10. WA7PRC
    Now Lee, let's not bring fishing into the discussion.
    Oh, wait... different kind of trolling! :eek:
ad: hrd-2
