TYT TH-9000D Locked Up
Discussion in 'General Technical Questions and Answers' started by AD7BF, Feb 29, 2016.
  1. AA5CT
    AA5CT Ham Member QRZ Page
    Geoffrey, are your TYT radios still working okay after your fix?
    de Jim
  2. N5MRG
    N5MRG Ham Member QRZ Page
    Add two more TYT TH-9000 radios to go tits up. Same issue... display giberish and locked up.
    Geoffrey appears to have a different issue going on. All of the failures I have had have never lost 5v to the cpu.
  3. N5MRG
  4. N5MRG
    I finally received a response from TYT. They said they read this thread and watched the youtube video and their engineer says its a bad CMX138. The CMX138 is the voice scramble IC. LOL
    I guess the terms "display scrambled" didn't translate well.
    They want $28 for the part that will not fix the problem.
    No more TYT products for me.
  5. KA9JLM
    Do you / Did you have voice scramble turned on ?
  6. AA5CT
    Sure ... per FCC rules which are quite clear, I think, on this issue ...
  7. N5MRG
    Add another failed TH-9000 to the list.
    Same issue.
  8. N5MRG
    After many hours reverse engineering the TH-9000 I have come up with a repair.
    I have successfully repaired several and have enough components to repair three more.
    The repair is not for the faint hearted, requires a hot air rework station, keen eyes or microscope and a steady hand.
    The problem is a design flaw where TYT used a dsp device that has an absolute max VCC rating of 4.5 volts.
    In the circuit they are powering it off if the 5 volt 7805 regulator on the main pcb. The CPU located on the display board has its own 5V regulator located on the display board. The problem is not the CPU.
    I am interested in purchasing your dead TH-9000 to use as parts. They must be complete radios with no attempted repairs.
  9. KF5ZQB
    KF5ZQB Ham Member QRZ Page
    N5MRG I have a TH-9000D that would like to ship to you if you still want them. It has the jumbled screen. I have no need for it and if you can fix it and use or do something with it. It is complete and has not been messed with. I will pay shipping.
ad: w5yi
