Tube spec questions
Discussion in 'Amateur Radio Amplifiers' started by KI7RPM, Sep 10, 2019 at 7:13 AM.
  1. KI7RPM
    KI7RPM Ham Member QRZ Page
    I am looking into building my own HF amp Nothing fancy 600 to 800 watts out
    being driven by a kenwoodTS-440S 100w out im only wanting to use it on 80-10 M SSB
    Im thinking on using a pair of 572b tubes Grounded grid design
    Here's My Issue
    on the spec's im looking for the drive power (I.E. the output power of my Radio)
    That the tube will Accept so what tells me the input(drive) power and the RF output on transmit
  2. N8FVJ
    N8FVJ Ham Member QRZ Page
    Figure about 65 watts input for about 700 watts PEP out for a pair of 572B tubes.
  3. WB2WIK
    The old Cetron sheet you show doesn't list typical operation parameters.
    Here's one that does: https://frank.pocnet.net/sheets/164/5/572B.pdf
    It says typical operation is "driving power 50 Watts," which is a per-tube rating for a GG linear amplifier and is about right.
    WQ4G and KI7RPM like this.
  4. AC0OB
    AC0OB Subscriber QRZ Page
    For simplicity it is difficult to beat the Dentron design for the DTR-1200L
    Pheel
  5. KI7RPM
    All Thanks so much for the info AC0OB and WB2WIK
    thank you for the pdf files they are saved in my amp files
    im sure ill have many other questions in the future
ad: M2Ant-1
