TS-530s can't peak load control
Discussion in '"Boat Anchor" & Classic Equipment' started by KD5NDQ, Apr 14, 2019.
ad: DLSpec-1
  1. KA9JLM
    Answer these questions. ^^^
    Set both covers aside, Not both tubes.
    And do not stick your fingers in the HV cage with power on.
  2. AI3V
    AI3V Ham Member QRZ Page
    You are alternating between posting that you have either 40,60,70,90,200 ma and that you either can or cannot dip the current.
    Good luck to you.
    Rege
  3. WB2WIK
    Yeah, it would be hard to get the tubes to light up if you set them aside.:)
    KA9JLM likes this.
  4. KA9JLM
    Not if it is daytime and the sun shines on them. :cool:
  5. KD5NDQ
    KD5NDQ Ham Member QRZ Page
    I hope it turns out the simplest thing that I should have checked first is the solution. After trying 2 separate patch cables to the 300W dummy load I tested each and found one did not have continuity and the other had a short between the center pin and shield. These were both soldered PL259 connectors with RG8/X cable. I don't have any others to test with but have ordered a couple of patch cables that will be here Monday. I hope this makes a difference as to why I have been seeing spurious readings. It also makes me wonder if this is why I never saw anything signalwise on the cheapee Dentron SWR/wattmeter I tossed a while back..
  6. K7TRF
    Yup, posted something along those lines a week ago:
    KD5NDQ likes this.
  7. KA9JLM
    Sounds like you are making progress.
    Good Luck.
    KD5NDQ likes this.
  8. KD5NDQ
    Sorry, I obviously missed this the first go round! Thank you
  9. KD5NDQ
    Thanks and thanks to everyone here!
