TS-530s can't peak load control
Discussion in '"Boat Anchor" & Classic Equipment' started by KD5NDQ, Apr 14, 2019 at 1:41 AM.
  1. KA9JLM
    The ones in the HV cage also ?
    Are all of the wafers aligned properly ?
  2. KI4AX
    KI4AX Ham Member QRZ Page
    Try cleaning the Relay Contacts. I believe there are two relays in the TS-520 - clean both of them.
    Dan KI4AX
  3. KD5NDQ
    KD5NDQ Ham Member QRZ Page
    Yes and yes. The capacitor plates fully meshed has the PLATE indictaor just a little CCW of 3.5.
  4. N8YX
    N8YX Ham Member QRZ Page
    Another question: Does this happen on all bands, or just the lower (20M and down) ones?
  5. WB2WIK
    Not TUNE, which runs greatly reduced power.
    What is Ip in CW with CAR control advanced so that the ALC meter indicates? Should be 200mA or more. And if it is, what does "HV" read at that time? It should drop a bit lower than when "idling," e.g., from maybe 880V down to 800V or something. That drop would be normal under full load, it's a voltage-doubler power supply.
  6. W5RKL
    W5RKL Ham Member QRZ Page
    It's possible the Band Switch shaft coupler is cracked/broken, preventing the band switch
    wafer inside the final amplifier from rotating the same as the main band switch wafers
    on the RF Unit board. When this happens, the final amplifier band switch wafer will not
    rotate properly with the RF Unit band switch wafers, resulting in no dip in PI current
    in TUNE and CW mode.
    To check the band switch coupler, power the 530 OFF, remove the covers, remove the
    cover on the final amplifier, remove the front 6146, and pay attention to the band switch
    assembly inside the final amplifier while rotating the band switch knob. The final amp
    switch and the RF Unit switches should rotate exactly the same. If they do not, the final
    amp switch does not rotate, then the coupler is more than likely cracked/broken and
    needs to be replaced.
    Steps to replace a cracked/broken band switch shaft coupler in a Kenwood TS-530.
    Step 3 below that states to slide the band switch shaft from the coupler, do NOT remove
    the band switch knob and do NOT remove the long band switch shaft from the radio!!
    Slide the long band switch shaft out towards the front of the radio just enough to clear
    the coupler so the coupler can be removed!!!
    1. Removing the front 6146 final tube provides access to the band switch assembly
    inside the final amplifier enclosure and the coupler set screws. Do not attempt to
    loosen the coupler set screws without removing the front 6146 final tube.
    2. Set the Band Switch to 3.5.
    3. Loosen both sets of set screws and gently pull the band knob and long switch shaft out
    towards the front of the radio just enough to remove the coupler
    4. Look closely at the final amplifier band switch assembly shaft inside the final amplifier.
    There are '2" flat spots on the switch shaft. Rotate the final amplifier switch assembly shaft
    inside the final amplifier so the flat spots are as follows:
    One flat spot is exactly horizontal on the top of the shaft and the other flat spot is exactly
    vertical on the side of the shaft closest to the front final amplifier tube. The shaft flat spots,
    when the shaft is set correctly, will be like an "Upside down L" as viewed from the front of the
    radio!! The bottom of the "L" will be on top exactly horizontal and the vertical side of the "L" will on
    the "right", exactly vertical. The band switch shaft inside the final amplifier must be exactly as
    stated.
    5. Slide the coupler onto the final amplifier enclosure switch shaft assembly and tighten
    the sets screws on that final amplifier band switch shaft end of the coupler.
    6. Rotate the band switch knob so the knob points to exactly "10" (NOT 10 meters)
    7. Slide the long band switch shaft into the other end of the coupler and tighten the set
    screws
    8. Rotate the band switch and watch the band switch assembly inside the final amplifier
    enclosure, it should rotate exactly the same as the long band switch shaft. If it does then
    replace the final tube, the cover over the final amplifier, the top and bottom covers on the
    radio, you're done.
    If you want to see where the final amplifier band switch assembly is located and where the
    coupler set screws are accessed, look at Ken, K4EAA website link below
    https://www.k4eaa.com/couplers.htm
    Mike W5RKL
    www.w5rkl.com
    KA9JLM likes this.
  7. W5RKL
    There is a mistype in my previous response. I typed "PI" instead of
    "IP" in the last sentence of the first paragraph.
    In TUNE mode the final amplifier screen voltage is reduced by approximately 50%
    which will result in a reduction in the final tube IP meter (cathode current) indication.
    In CW and any SSB mode the final tube screen voltage is returned to it's normal higher
    voltage level. Switch to CW mode, turn VOX ON, and press the CW key, the IP meter indication
    should be higher. If rotating the PLATE control does not result in a "DIP" in IP meter indication
    when the PLATE knob pointer points within the White silk screen label of the band switch
    setting then it's quite possible the band switch coupler is broken. Cracked/Broken Band
    Switch couplers is not uncommon in these Kenwood hybrid models. I've had to replace the
    Band Switch coupler in a few TS-530s in the past.
    Mike W5RKL
    www.w5rkl.com
  8. KD5NDQ
    All bands
  9. KD5NDQ
    It reads roughly 75ma
  10. WB2WIK
    75mA key down on CW indicates something's definitely wrong.:)
