Threat to Amateur Radio 23cm band
Discussion in 'Amateur Radio News' started by G4TUT/SK2022, Aug 17, 2019.
  1. W1YW
    The objective of PRC manufacturing at RF is to make 'universal' RF exciters and let the country of origin deal with that reality. Essentially PRC is leading the pack to force the world to go from 'SDR' to 'SDWT' (software defined wideband transceiver) with cognitive radio...
    Is that a good thing?
    IMO the answer is absolutely not. It destroys the notion of allocation AND enforcement.
  2. W1YW
    Several Zedders have asked me offline where the allocation issue is going.
    Here is my perspective (somewhat simplistically stated)--
    In 5 years we will see a drastic paradigm shift--implemented substantially--on frequency allocations. There will be far fewer non-government service 'sole' allocations. Most allocations will be 'multi-use' rather than 'primary'; 'secondary'; 'sole'.
    MOST applications will be forced to deal with waveforms rather than frequencies/bandwidth. For example, low data rate systems will be 'channelized'. High data rate systems will be wideband and leveraged across several (prior)bands, raising the 'interference temperature' (that is, noise floor).
    Many non-government legacy systems/modes will be phased out.
    Cognitive radio--where the system finds an 'open frequency' will be dominant .
    How does ham radio fit into this?
    Well, right now we have allocations. When we use them, and when we execute the PART 97 MISSION (in the US), we become an important backbone and backup.
    We need to show the above, now, in greater numbers and executed plans.
    For example, Field Day shouldn't be a camping trip, contest, or excuse to roast Boston Butt--
    • We need to have many, and wider coverage, simulated emergency networks.
    • We need to essentially also have a voluntary 'mandatory use' where we show evidence of being OTA a minimum number of hours a year (for example).
    • We need more operating events, across all the ham bands. We need to make our numbers clear--we ARE a force.
    So, what are your suggestions, to thwart the threats to allocations?
    There are more hams in the US than ever before...yet the use of spectrum per US ham is at an all-time low...time to change that.
    Chip W1YW
  3. NN4RH
    I do agree with the the premise and rationale but I see some practical (and emotional) issues many will have with some of the three bullet points that will make them hard sells.
    OK but there are several ways to adjust that ratio, so watch for unintended consequences.
    W1YW likes this.
  4. W9KEY
    W9KEY XML Subscriber QRZ Page
    Hum - Sounds like yet ANOTHER reason not to buy an ICOM IC-9700
  5. W6RZ
    W6RZ Premium Subscriber QRZ Page
    A 5 year timeline seems wildly optimistic to me. Just look at 3.5 GHz CBRS. It was established in 2015 and it's still not being used. Or the close to zero penetration of TV white space devices.
    Also, there's plenty of push back to cognitive radio. Cellular carriers paid dearly for their frequencies and expect/demand sole access. Even the DoD seems fed up with being a primary target for reallocation (with the resignation of David Redl).
    Many agree that cognitive radio is the way to go, but actually implementing it will take many moons.
  6. W6RZ
    Be aware that the FCC has not approved use of the Galileo E6 signal in the US.
    http://www.arrl.org/news/fcc-approves-use-of-galileo-global-navigation-satellite-system-in-the-us
    "The Order does not grant access to the Galileo E6 signal, which is transmitted over the 1,260 – 1,300 MHz frequency band, since this band is not allocated for RNSS in the US or used by the US GPS to provide position/navigation/timing (PNT) services. The FCC pointed out that granting access to the Galileo E6 signal could constrain US spectrum management in the future in spectrum above 1,300 MHz, where potential allocation changes are under consideration.
    The omission of the E6 signal also means that radio amateurs would not have to protect Galileo receivers from interference on 23 centimeters, which has been a significant issue in Europe."
    Here's the complete FCC order.
    https://docs.fcc.gov/public/attachments/FCC-18-158A1.pdf
    KA2FIR and K6CLS like this.
  7. W1YW
    I think the avaliability and the need will force that 5 year time scale.
    I actually hope I am wrong;-)
    The 'carrier landscape' is increasing now, after years of consolidation. Just watch.
    Chip W1YW
  8. W1YW
    The Galileo mess is a splat we did NOT produce...
  9. KA2FIR
    KA2FIR Ham Member QRZ Page
    Who’s the troll?
  10. W1YW
    Name of troll appears to be ..."everyone".
    KA2FIR likes this.
  11. AG6QR
    It's not just a matter of their intentions, it's also a matter of our own.
    The US has presidential elections every four years, and congressional elections more often than that. We can radically change policy much more quickly than a new satellite navigation system can be deployed.
    If Europe fails to deploy an independent system today, they are taking a gamble that we will continue to want to be their ally, and we will continue to be the kind of nation they want to ally themselves with, for the next several administrations, at least.
    Even though I firmly believe we will continue to be a worthy ally, I don't blame them one whit for carefully hedging their bets and putting their own interests first, just as we put our own interests first.
    W1YW likes this.
  12. WY7BG
    WY7BG XML Subscriber QRZ Page
    Alas, I agree. 220 MHz is a great band and Icom should have supported it. It's left a HUGE opening for competitors.
    73 de WY7BG
    KA2FIR likes this.
  13. WY7BG
    This is, in large measure, due to bureaucratic and regulatory blunders over at Fox Charlie Charlie.
    The spectrum management systems required by the CBRS rules are just barely being put into place. And the companies which are running those systems are trying to profiteer from them, requiring every user to pay a monthly tax, per device, to use the spectrum. Needless to say, this will discourage CBRS adoption.
    What's more, the FCC has pandered to the large mobile carriers by enlarging the geographic areas in which CBRS channels will be exclusively licensed - effectively turning CBRS from a "Citizens' Broadband Radio Service" into a "Cellular Broadband Radio Service." This, again, has discouraged use of the band as a whole. Why invest in a band if the cellular providers are going to shrink the amount of spectrum available to you more and more over time, while you - whether you're a commercial user or a noncommercial one - have not a chance of getting one of those licenses?
    In short, the problem with CBRS - as with the threat to hams' allocations - is corporate influence. Corporations are greedy for spectrum - both to use for themselves and to hoard so as to lock out competition.
    Amateur radio will soon have to steel itself for a fight for its very existence.
    KA2FIR and W6RZ like this.
  14. W1YW
    I see no evidence that greed is what is driving the allocations question. And the FCC should be faster, but they are hardly the enemy by any definition.
    The driver is obviously the needs and urgency of over 280 million users of the smart phone era in the United States.
    A great example of a nebulous solution that has not lived up to promises is the WISP(A) system, which may or may not make the 'last mile' broadband solutions viable in rural America.
    Much of this will, IMO, be moot when the SAT constellations take over.
    As to "existence"-- use it or lose it.
    Chip W1YW
    KD7HCW likes this.
  15. KD7HCW
    KD7HCW Ham Member QRZ Page
    This is pretty much the answer for where we have primary allocation. The frequency vultures are always circling, and when there's dead air it just gives them a reason to claim that range like a medieval land grab scheme. I work both HF (digital / SSB) and VHF/UHF (FM repeaters), and while HF is busy especially on weekends, I'll drop my call to dead air several times a day on the repeaters to no reply. They're basically used for nets around here. I wish more people would just turn on their radios in their car or while they're futzing in the garage at home to keep the bands active.
    Sorry for the slight digression, but W1YW made an important point in general, and I wanted to vent where I saw the biggest risk from lack of use.
    -Lou
    W1YW likes this.
ad: LZQSLprint-1
