the Process of BUILDING an Amateur Radio CAR!
Discussion in 'Ham Radio Discussions' started by WA6MHZ, Jun 18, 2016.
  1. KV6O
    KV6O Ham Member QRZ Page
    Does shutting it off and then restarting clear the issue? Does an "idiot" light illuminate? Maybe disconnect your added stuff at the battery for a few days to see if it comes back up?
    Steve
    KV6O
    WN6U likes this.
  2. WC5P
    WC5P Premium Subscriber QRZ Page
    I dunno about Phords, but the Bosch alternators on European cars can get intermittent like that when the brushes get worn down to nubs. On the Bosch alternators, the brushes are easy to change, in fact it can be done with the alternator still in place if there is enough room in the engine compartment to reach it. Again, I dunno about Phord alternators. Those might have to be sent to Elbonia for rebuilding.
  3. WA6MHZ
    WA6MHZ Subscriber QRZ Page
    Several restarts did NOT clear the no alternator charge. what cleared it last time was putting a charger on the battery overnight
  4. WA6MHZ
    The good news is that I fixed the APRS Display problem by installing a 10K pot. Now I can adjust it for best readout. IMG_7023a.jpg
  5. KV6O
    Disconnect all your stuff and drive around for a week to see it comes back. But again, did the car indicate that there was a problem? Charging systems today can go that low to save fuel if the electrical load is light.
    Did you follow Fords instructions on adding radios to a Ford? They DO have service bulletins on this sort of thing. There's a hall effect sensor that monitors the load and the computer can alter the voltage to compensate. 12.9 is within the range of what a modern charging system will adjust to.
    Many have told you this but you refuse to listen. TAKE IT TO A PROFESSIONAL and have the wiring done properly by someone who understands how to wire a modern car.
    Some ford specific info:
    https://www.fleet.ford.com/truckbbas/topics/2012/modGuide.html
    https://www.fleet.ford.com/truckbbas/non-html/Q130.pdf <-- gets into some of the issues adding electrical loads and radios to non police package equipped vehicles.
    Steve
    KV6O
    NL7W, WN6U, WZ7U and 1 other person like this.
  6. WZ7U
    WZ7U Ham Member QRZ Page
    Yes, before you do some REAL damage to something. Please.
    N2EY likes this.
  7. AC8UN
    AC8UN Ham Member QRZ Page
    You guys need to give up, knowledgeable people have been trying to tell him this for 3 months. He's too stubborn to listen.
    KD8HLY and N2EY like this.
  8. WA6MHZ
    I dont know WTF is going on. This morning it got better, but was bad all yesterday afternoon.
    Nothing to do with radio. NO way I can damage the system. But I did notice they put the trailer wiring to the fuse box. So maybe I will hook it to there if the fuse is big enough. And put the ground on the chassis instead of battery negative terminal.
  9. WZ7U
    What is "IT"? o_O C'mon man. Did you even read the factory TSB's?
    Does the Nun know she is riding around in a rig full of maybes and half asses? :eek:
    I'm not trying to bust your balls Pat for no good reason here. I lost patience with the whole power wire through the door opening thing and this latest round sounds like stubborn over reason talking there.
    Just sayin man. No malice intended. :oops: Maybe AC8UN is right, but I would like to think otherwise. I gotta wonder if you'll even make it to Hawaii
    N2EY likes this.
  10. KC4YLV
    KC4YLV Ham Member QRZ Page
    this thread is epic and to suggest that we be deprived of the inevitable hilarity of a series of pictures of a burned out Ford Flex is cruel.
    AC8UN and N2EY like this.
