ad: UR5CDX-1
The lowest power to work birds
Discussion in 'Satellite and Space Communications' started by IZ8XOV, Jan 12, 2018.
  1. K3RLD
    K3RLD Ham Member QRZ Page
    15 years of racing cars, riding motorcycles, and pulling triggers has already ruined my hearing. I just remember the conversation from last year! :p
    K6LCS likes this.
  2. WA9SVD
    WA9SVD Ham Member QRZ Page
    I've been remiss lately on satellite operations, but in the past, I was able to access the LEO Sats with little more than 2 H-T's (one for 2M, and one for 70 cm) with nothing more than a (supposed 5 Watts) into an after market (Diamond) whip for the 2M uplink, and a standard easily obtained aftermarket (again, Diamond) "rubber duckie" antenna for the downlink. Granted, a small 70 cm Yagi for the downlink would have been MUCH better on 70 cm, and plans can be found by "Giggling" "Cheap Yagi's." on the I'net. A five element antenna should be more than adequate. For hand-held, semi-permanent or weather exposed materials, marine varnish would probably be a wise investment for the wood portion. On the other hand, a "bicycle" type hand grip works as well.
    WD9EWK likes this.
  3. W1VT
    W1VT Ham Member QRZ Page
    I was able to work Oscar 13 with 6.5 watts to a calculated 14 dBic 436 MHz Yagi. I made half a dozen confirmed CW contacts through a high earth orbit satellite. As I recall the orbit was close to apogee, which simplified antenna pointing.
    Zack W1VT
  4. WD9EWK
    WD9EWK Ham Member QRZ Page
    With any of the current FM satellites, I have had no problem with 5W HTs and a directional antenna (Elk log periodic). On higher passes of AO-91 specifically, I have used a long duckie antenna and as little as 100mW (low power from a Yaesu VX-3R) with an MFJ-1717 long duckie antenna. Using the Elk, 100mW from the VX-3R or 500mW from other HTs can get through when stations are operating courteously on AO-91. Some have even used as little as 50mW from a TH-D72 to either a directional antenna or long duckie with this satellite, but I have not been successful with the 50mW level. Maybe I will try that over the weekend on a late-night AO-91 pass, when things aren't as busy as the afternoon passes.
    73!
