The currently applied filter(s) produced no contacts. ERROR
Discussion in 'Logbook User Forum' started by N9AGC, Jul 31, 2019.
  1. N9AGC
    N9AGC XML Subscriber QRZ Page
    I am having issues with the subject line error message when analyzing the logs under the awards section.
    Under WAS I have several states that are showing confirmed but when you click on the entry it gives the error message instead of the QSO/QSL info.
    It also fails to export the contact to LOTW either.
    Any suggestions?
  2. W1DQ
    You have not completed the filter definition in the case of "QSO matches …" You need to additionally choose the match criteria (e.g. confirmed; unconfirmed; flagged): viz.
    Unable to replicate 50 States problem, seems to be working.
    Detailed report for send to lotw on Wed Jul 31 03:27:57 2019:
    0 out of 3499 records sent.
    Records already sent: 3499
    ADIF output errors: 0
    TQSL Signed Successfully: No
    Uploaded to LoTW Successfully: No
    Suggest re-setup LoTW Access or contact: https://ssl.qrz.com/support
