Tarheel on Travel Trailer
Discussion in 'On the Road' started by N1SFT, Jul 22, 2019.
  1. W5LZ
    W5LZ Ham Member QRZ Page
    ... So, did you get an antenna up and working?
  2. KE5XA
    KE5XA Ham Member QRZ Page
    Greetings Craig,
    I have a LittleTarheel II on my RV, and attached it to the top of the ladder on the rear of the motorhome. I used Foil HVAC tape that I got from The local hardware store and cut tuned radials. It works OK. One suggestion, make sure that the adhesive is conductive. I would recommend that you re-consider laying the antenna down pointing aft or to the rear of the trailer. While travelling during rain storms/bad weather, rain will find it's way into the antenna as the bottom sleeve is not sealed. This could be disastrous for the coil and the motor/gearbox. I lived up north for quite a while and the residual salt and from winter and water will not be kind to the inside of the antenna.
    Just some thoughts. Good Luck.
    Milton KE5XA
