ad: portazero-1
SWR question (Bad swr on higher power only) 2 meter
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by N6DDR, Nov 14, 2012.
  1. N6DDR
    N6DDR Ham Member QRZ Page
    Hi, I have a copper J-pole on the roof of my house. My swr on 146.520Mhz FM is as follows:
    1/2 watt = between 1.0:1 and 1.1:1
    9 watts = 1.2:1
    130 watts = 2.5:1
    160 watts = 4.5:1
    Why would it be so good on low power and bad on high power?
    P.S. I am running RG8-X (mini-8) coax. (about 60')
    Thanks,
    73's
    Sounds like a problem with the SWR meter. What are you using for that?
  3. N6DDR
  4. N6DDR
    My bad, I didnt re-calibrate meter when I switched to high power. I guess I need to CAL if I want to check different power levels... So at 130 Watts its 1.3:1 :)
  5. WB2WIK
    Yep. You need to CAL any time you change power at all, and usually also if you change frequencies or change antennas.
ad: Hamcestry-1
