Strange TS930S PA Fault
Discussion in 'Radio Circuits, Repair & Performance' started by G3YRO, Dec 2, 2017.
  1. G4COE
    G4COE Ham Member QRZ Page
    I mentioned measuring R14 the current monitor just in case anything has happened to it due to the excessive current as a precaution.... I dunno how tough this resistor is.
    Dave
  2. G3YRO
    G3YRO Ham Member QRZ Page
    It's only had the excessive current for less than 2 seconds at a time, max ! (and even on receive, I turned the rig off straight away)
    So I presume that resistor is OK.
    But you're right - at some point when I have it apart it might be worth wiring a meter in series with the PA feed to check its calibration.
    Roger G3YRO
  3. G3YRO
    Well I've used the 930 for a couple of hours on CW the last couple of nights, to get the PA warm . . .
    I'm pleased to say there has been no sign of the problem re-occuring (I'm continually monitoring PA Current now, to see any signs of change!)
    So hopefully this problem WAS that dirty Bias pot changing contact when hot.
    However . . . I do now appreciate there MAY still be a problem with one of the PA transistors going leaky between Collector and Base when hot . . . so I will keep my eyes open. (and report back if it happens again)
    Thanks everyone who offered advice. (even if you end up self-diagnosing, I find it really useful to discuss faults on here . . . it makes you think things through properly)
    Roger G3YRO
  4. KA9JLM
    I would be tempted to fuse the PA supply, Like many radios do.
    I hate when a RF out transistor becomes the main fuse protector.
    Have Fun.
  5. G3YRO
    Kenwood put a 20 amp fuse soldered inside the rig in the supply line . . .
    Roger G3YRO
