SDR Receiving on iPhones and iPads with apps from the appstore
Discussion in 'Software Defined Radio (SDR)' started by K1LPI, Jan 9, 2019.
  1. K1LPI
    K1LPI Ham Member QRZ Page
    There are two apps in the Apple App store that allow you to stream SDR data (I/Q data) from RTL-SDR dongles and Airspy HF+ SDR receivers. They are "SDR Receiver" $9.99, and "rtl_tcp SDR" , $9.99.
    Both apps make use of the computing power and displays of these powerful IOS devices and require the use of an external server running a dongle or HF+ sdr receiver to provide the I/Q data stream. That is because there is currently no other way to get the data from USB SDR devices into a lightning port and IOS does not support drivers for these devices. A work-around is needed.
    The easiest way to do this is with a Raspberry Pi computer using the RTL-SDR library and rtl_tcp utility. Similarly the HFP_tcp server can stream data from an an Airspy HF+ device. Data can be streamed over the WiFi Lan from the Pi to the iPhone or iPad. Another approach is to use a Windows machine running SDR# and use the SDR utilities rtl_tcp as with the Pi. Both authors have help pages to assist you in setting up these servers.
    Live real time demodulation of signals is done in IOS on your device. Monitor local repeaters, listen to aircraft, AM and FM broadcast, and what ever frequencies your SDR device covers. Give it a try.
    Disclaimer: I have been a beta tester for both apps. I do not receive any compensation for beta testing and have no financial interest in either app. 73 de K1LPI
    N6YWU likes this.
  2. KA8NCR
    KA8NCR Ham Member QRZ Page
    Which one works with the Airspy HF+?
    Edit: Found it, it is SDR Receiver. But caution, it only supports AM and FM demod.
  3. N6YWU
    N6YWU Ham Member QRZ Page
    The other app, HotPaw "rtl_tcp SDR" (mine) does support SSB demodulation.
    https://itunes.apple.com/us/app/rtl-tcp-sdr/id1351164646?ls=1&mt=8
    Source code to a very basic rtl_tcp work-alike for the Airspy HF+ is here:
    https://github.com/hotpaw2/hfp_tcp
    No build instructions, but there is a makefile.
    So both iOS/iPhone apps will work with an Airspy HF+ using the above rtl_tcp emulation code (and a Raspberry Pi as an iPhones USB adapter).
