SB200 Rotary Switch replacement
Discussion in '"Boat Anchor" & Classic Equipment' started by W1DLA, Nov 17, 2010.
  1. W1DLA
    W1DLA Ham Member QRZ Page
    Latest in the SB200 rebuild struggle...the rotary switch for the meter is busted, some contacts completely broken off...it shows HV but nothing on other settings and I found a post by N4NAB that seems nearly identical in nature.
    But, I'm having a hard time figuring out a replacement switch...Mouser has a 5contact 2pole switch but it's only rated 0.3 amp and not as heavy duty looking as the wafer switch in the SB200. And, the manual has no real information about the switch needs. Any suggestions for a substitute or will the Mouser 1 105-SR2511F-25NS handle it if it's just meter current?
  2. KC8VWM
    KC8VWM Ham Member QRZ Page
    Is it just the solder tabs on the rotary switch for the wiring that are broken off or are the switch contacts entirely disintegrated?
    Is it repairable?
  3. W8JI
    W8JI Ham Member QRZ Page
    I have wafers that will work, and are better desiged.
  4. W9GB
    Doug -
    ElectroSwtich in North Carolina has acquired a majority of the US rotary switch manufacturers
    (e.g. Oak / Grigsby, Stackpole, Shallcross, ASM, Centralab (CRL) and Eaton) over the past 15 years.
    Many of these manufacturers were in the Chicago area and industrial Midwest (hence Heathkit parts source)
    http://www.electro-nc.com/
    These switches have been used a lagre number of US manufactured
    electrical appliances and equipment.
    Electroswitch
    2010 Yonkers Road
    Raleigh, NC 27604
    US & Canada Toll Free Phone: 888-768-2797
    or 919-833-0707
    w9gb
  5. W1DLA
    SB200 Rotary Switch
    Thanks, I'll check the site. Appreciate the help.
    Someone mentioned a wafer would be better...don't doubt it but would the Mouser 0.3 amp rotary work?
    In response to other postings...it's a couple contacts that are broken off, not the solder tabs. There's been some arcing at the switch setting for grid current (which is broken) or at least spark evidence.
    Synopsis...I get an HV reading that's right but nothing on any other setting (In circumstances where I should, of course)...some have reported similar problems from switch and wiring mistakes in the original meter circuit...I'll trace it all but the switch definitely needs replaced regardless.
    Appreciate all the help folks.
  6. W1DLA
    When you say "I have" do you mean you have a place to buy one or that I could buy one from you?
  7. KB1JFQ
    KB1JFQ Ham Member QRZ Page
    Hi Doug, I sent you a PM here on QRZ.
  8. W1DLA
    Just to end this...I finally found a 5 pole 4 throw ceramic wafer rotary small enough in diameter to fit into the SB200 on ebay...usa made but sold from hong kong (strange world)...adapted one throw for the backside of the meter switch in the SB200 and the other wafer as the regular front side rotary in the SB200, had to do some tedious splicing to the old wiring but got it solved. The lack of standard terminology on ebay and the fact that no one posted diameters led me to buy two unsuitable switches in the process...but, live and learn.
  9. W9GB
  10. W1DLA
    I did...Harbaugh doesn't carry the switch. I did chase one down (china wholesaler), got all the tedious wiring done and it's working great....tnx.
