Sb-200 weird thing happening
Discussion in 'Amateur Radio Amplifiers' started by KN4CTD, May 15, 2019.
  1. KN4CTD
    KN4CTD Ham Member QRZ Page
    One resistor measures 108 ohms and the other measures .2285k ohms according to my lcr meter.
  2. W1QJ
    W1QJ Ham Member QRZ Page
    Bingo make new ones with nos carbon comp 2 watt resistors
  3. KN4CTD
    Is it necessary to use carbon comp resistors I have some 47 ohm metal oxide? 3 or 5 watt resistors. And I have some 2 watt 100 ohm metal film resistors. I have new copper wire to rewind either with.
  4. KJ4YEV
    KJ4YEV Premium Subscriber QRZ Page
    Due to their non-inductive properties, Carbon comp is definitely the best choice if you can find them. They're getting harder to find. The Metal Oxide film types are probably spiral deposited film. You can also use a pair of 100 Ohm, one inside the inductor, the other outside.
  5. WA7PRC
    WA7PRC Ham Member QRZ Page
    108Ω is barely usable; 228Ω is too high. The resistor needs to have low inductance (carbon composition meets that need). Though 2W cc resistors are no longer manufactured, I found eBay seller 'bigsmythe74' (http://www.ebay.com/str/bigsmythe74) sells NOS 2W carbon composition resistors. Since it doesn't have to be precisely 47Ω, I searched on price, and found 56Ω available for $1/ea + $4 shipping/order (http://www.ebay.com/itm/400880759592). :)
    The datasheet for the Allen-Bradley cc resistors sold above shows Z/R ratio very close to 1. I've measured L = about 17 nH. :)
    K7TRF likes this.
  6. K7TRF
    Definitely replace that as well.
    As posted earlier check everything in and around the grids as problems there can also lead to oscillations.
  7. AA5CT
    AA5CT Ham Member QRZ Page
    Holy cow!!
    You will have RF currents "flowing" into your power supply w/o a bypass cap!
    You realize, a PA plate "choke" is really just a low-Q inductor that works to achieve parallel resonance (Hi-Z) in conjunction with the Plate tuning capacitor?
    W8JI does a yeoman's job explaining this ... on the higher bands the design of the so-called "Plate choke" becomes a little more complicated (as the choke has some frequencies outside the ham bands where the PA plate choke can go SERIES resonant. THIS might be the core of the issue with this SB-200 maybe?)
    It's worth taking a little time to review his webpage on this subject:
    https://www.w8ji.com/rf_plate_choke.htm
    BTW, I *still* have RF getting by my RF bvpass cap on the 'cold' end of my plate choke on the 160 meter band on an old LK-500Za ... this is evidenced by the meter lamps glowing **brighter** when driving RF into the amp and the amplifier is ON, delivering RF to the output jack ... CLEARLY RF is getting into the 12V rectifier circuit, being rectified, and the bulbs get BRIGHTER when speaking into an SSB radio, OR using the amp with the rig in CW ...
    I added a few thousand pF doorknob cap to the cold end of the choke, but, not much of a change took place, the meter lamps STILL glow brighter when the amp is outputting amplified RF on the 160 meter band ... the other bands (80 meters and up) are okay. Only on the 160 meter band do I have this issue ...
    WA7PRC likes this.
  8. KN4CTD
    I’m gonna try and locate a suitable replacement for that missing cap today. I don’t have any hv bypass caps on hand. I didn’t realize it was missing until yesterday
  9. N6UH
    N6UH Ham Member QRZ Page
    What value is the "extra" one that was under the chassis? Could be some one moved it
  10. WB2WIK
    The one under the chassis is part of a tuned network with a coil, it's not bypassing the B+: The network is installed across the LOAD capacitor, placing it in parallel with the RF output.
    If there's no bypass at the bottom end of the plate RF choke, that is a big problem!
    WA7PRC likes this.
