Samsung Android Echolink. NOTES
Discussion in 'Echolink/IRLP Tech Board' started by SM0KJD, Mar 29, 2012.
  1. SM0KJD
    SM0KJD Ham Member QRZ Page
    samsung galaxy s wifi
    Sansung KIES (YP-G70)
    1, I have just bought a Samsung Galaxy S media player YP-G70CW/NEE,
    when I run Echolink it repeats words several times when I talk.
    Hate to say it it echo´s .... hi
    Looking around it seem´s that not only Samsung but iphone/pad
    has the same problem.
    I met G4MUV on Echolink a week ago and he has a Samsung phone
    that echo´s some what... but when he got home and went on his
    Samsung Pad, it was aufull, as bad as my YP-G70CW/NEE
    2, Also the (cable)headset does not work on echolink that will say
    it beeps in the head set when I start or stop Echolink but all
    other audio goes to the built in speaker.
    3, BLUETOOTH
    Non of my blue tooth headsets work they are V 2.1
    just a GPS,ASUS 10" and the car analyzer unit work.
    Here in Sweden a V3.0 a2dp headset costs pounds 100 or more, but I
    talked to a nice "salesman" and he unpacked a v3.0 a2dp headset
    and it coppled up, But only the audio worked and not the mic.
    (G4MUV Steve´s Samsung W can use the mic and not the audio....)
    (Skype works well and with the cable headset)
    All the best SM0KJD
    2nd TEXT---------------------------------
    Follow up.
    Last night Samsungs program Kies said it wanted to do an upgrade,
    the upgrade went well...
    It said, it had succeeded in installing the new upgrade, BUT at the same time,
    I received a message about a driver, you can see them in the
    attachments/(below)*
    1, USB Device*
    One of the USB devices attached to this computer has
    malfunctioned, and Windows does not recognize it.
    For assistance in solving this problem,click this message.
    2, Device driver*
    software was not successfully installed
    SAMSUNG Mobile MTP Device Failed.
    Now the player will not accept Kies anymore.
    But I do now have control over the headset in
    Echolink.
    Every thing else seems to work
    THIS IS NOT AN UNUSUAL FAULT IF U LOOK ON THE NET.....
    This what I have now:-
    Firmware 2.3.5
    Kernel version 2.6.35.7-G70XXKPE-CL562492
    se.infra@SEI-28#2
    Build number GINGERBREAD.XXKPE
    3rd TEXT.............................................
    DRIVER PROBLEM
    SAMSUNG´S website says that you need to have
    the Unsigned drivers enabled on your computer. I suggest that you enable
    the unsigned drivers and check if it works. QUOTE TAKEN FROM THE LINK BELOW.
    Follow the below steps to boot the computer to ‘enable Unsigned drivers’:
    a. Restart your computer if it is powered on.
    b. Tap the F8 key after your computer initially powers on.
    c. Once you see the Advanced Boot Options menu you can stop tapping.
    d. Use the up/down arrow keys to highlight your selection.
    e. Select the option that says ‘Disable driver signature Enforcement’
    From this link :-
    http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/cannot
    -connect-samsung-captivate-get-an-error-mtp/466bb251-a5af-489e-baf2-809bc7f1cac3
    I tried the above first (DID NOT WORK) but forgot to "Enable" again
    while doing the below.
    Samsung Galaxy S wifi 5.0 YP-G70CW/NEE
    BEFORE you continue check the following.
    1, Wireless and network >USB settings>Samsung Kies should be MARKED/Enabled
    2, ...
    3, uninstall and install the latest Kies
    4, Then follow the below.
    Found at Link :-
    http://android.stackexchange.com/qu...reenshot-when-connecting-my-galaxy-s-to-my-pc
    1. Go to Samsung Kies software, on top left of the window, click the menu > Driver recovery.
    2. Let it reinstall drivers
    3. After driver installation finished, go to your phone, Settings> Application > Development, tick USB debugging mode.
    4. Under USB debugging mode connect your phone to the PC with USB.
    5. It installs correctly!
    6. Disconnect from PC
    7. Untick USB debugging mode
    8. Connect again
    and it works!
    FOR ME
    Rogan G4JWT/SM0KJD
