ad: MyersEng-1
Retevis RT82 Dual Band DMR Radio
Discussion in 'Amateur Radio News' started by BH6PJL, Jul 6, 2017.
  1. BH6PJL
    BH6PJL Ham Member QRZ Page
    RT82 is dual band dmr radio and operates in analog and digital modes on 400-480MHz frequencies on UHF and 136-174MHz VHF at up to 5 watts of power. It uses Time-Division Multiple-Access (TDMA) digital technology to double the number of users on a single 12.5kHz channel.
    As a dual band digital radio, RT82 is a little bigger than RT3/MD380 and RT8/MD390. You can have an intuitive contrast from the photo.
    RT82 has 6 keys can customize, three side keys 1,2 and 3. P1,P2 and the top orange key. The RT82 also has a trackball, and it’s embedded front and center. This makes the RT82 very different indeed.You can choose up, down, left and right by sliding the trackball. There is only one power knob, you can use it turn on the radio and change the volume. If you want to change the channel, you can realize it by trackball. Green key is “MENU”, Red key is “BACK”.Others are number keys. The yellow label “Owner” is a place you can write your name or callsign for your radio. Belt clip make you can carry walkie-talkie more convenient.
    SMA-M Antenna
    RT82 boasts 3000 channels, 10000 contacts, built-in CTCSS/DCS (analog mode only), single call, group call and all call, remote kill/stun/activate, transmit interrupt, VOX, TOT, Monitor, Scan, Talkaround and lone worker function. It is compatible with MOTOTRBO™ Tier I and II and is IP67 waterproof.(Note: RT82 is dust and waterproof only when the accessory port is properly covered and sealed. The radio is not fully waterproof when a headset or other accessory is connected.)
    RT82 support record function. Record function is only available on digital mode. RT82 can record for more than 8 hours when it’s 3000 channels&10000 contacts. Record check and playback is very easy. GPS is optional.
    • 3000 Channels
    • 136-174MHz+400-480MHz
    • Built-in CTCSS/DCS (Analog Mode)
    • 5W/1W Output Power
    • Repeater Capable
    • DCDM
    • 2200mAh
    • Emergency Alarm
    • VOX
    • Encryption (Digital Mode Only)
    • Private Call/Group Call/All Call
    • Text Messaging
    • Lone Worker Mode
    • LED Status Light
    • Color LCD Display
    • Lighted DTMF Keypad and Trackball
    • Signal Strength Indicator
    • Low Battery Alert
    • Battery Saver
    • Programmable Multifunction Keys
    • PC Programmable (Optional Software and Cable Required)
    • TOT
    • Keypad Lock
    • Audible Button Beeps
    • Clock
    • Drop-In Charge Capable
    • IP67 Waterproof
    • Audio Accessory Connector
    • DMR
    • Remote Stun/Kill/Activate
  2. N6NLX
    N6NLX Ham Member QRZ Page
    It appears to be the same as the Tyt MD-2017.
  3. CE1WFN
    CE1WFN Ham Member QRZ Page
    MD-2017 has GPS, 3000 Channels and will hold 10000 contacts
    W6COP likes this.
  4. AE9S
    AE9S Ham Member QRZ Page
    Anyone else get a laugh out of the first picture of the old man and his Field Day setup???
    Check out the 200' vertical he's carried out and setup all by himself. It's almost, but not quite, on top of the mountain in the background. I also dig his ridiculously over-sized solar panels casually propped up against the guy wires for his antenna, but not connected to anything. He sure doesn't seem to be using an RT82... Maybe he's calling for help on HF to report the gigantic levitating HT in front of him! And finally, are those miniature sheep in the background, or is he a maggot rancher?
    AF7EC, AD0JA and N3DAW like this.
  5. KF5FEI
    KF5FEI Ham Member QRZ Page
    I expect to see the Teletubbies any minute.
    G1YRV, KQ6XA, AF7EC and 2 others like this.
  6. N5JLD
    N5JLD Ham Member QRZ Page
    Looks like the picture is stolen. That is Jerry VE6AB. He has been on the cover of QST many times for his setups. He is also a Photographer.
    http://www.jerryclement.ca/
    AD0JA likes this.
  7. N5JLD
    AD0JA likes this.
  8. AE9S
    Wow - that is a BLATANT rip off! Not cool at all!!!
  9. W1YW
    Try this...
    G1YRV, W6COP, AF7EC and 4 others like this.
  10. W1YW
    Yehhh...
  11. K6MTS
    K6MTS XML Subscriber QRZ Page
  12. W1YW
    La-la with his dang FRACTAL ANTENNA...always nosing in on other people's business...
    G1YRV, AF7EC, KF5FEI and 2 others like this.
  13. W1YW
    OK..last one... ;-)
    Looks like a great lil' radio BTW...
    I love how the solar panels are up against the vertical--for maximum RFI from the inverters...
    KF5FEI and AD0JA like this.
  14. W0PV
    W0PV Ham Member QRZ Page
    Dirty OM's best be careful of those Teletubbies if you turn on the radio's "Promiscuous" mode!
    73 de John - WØPV
  15. AF7EC
    AF7EC Ham Member QRZ Page
    hahaha You all crack me up! :p
    W1YW likes this.
ad: Flexradio-1
