receive antennas only
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KB9MZ, Mar 8, 2011.
  1. KB9MZ
    KB9MZ Ham Member QRZ Page
    What are the things that make an antenna a "receive" form "only" when receive and transmit are supposed to be reciprocal when a direct 1;1 SWR exists without the use of a matching system?
  2. VK1OD
    VK1OD Ham Member QRZ Page
    Perhaps you need to give some examples.
    The reciprocity theorem for an 'antenna' does not imply reciprocity for the entire system. Doubling antenna gain (ie a 3dB increase) does double EIRP in a linear system, but for instance, it does not necessarily improve local received S/N ratio by 3dB.
    Owen
  3. KB9MZ
    An example would be a meander form of high density within a small circle. This will have a low noise factor if shielded
    because of low local noise pick up, but it can be resonant even tho having a small apartuure. However, because of the meander
    construction it can easily be resonant by not being electrically small. Another example is a multi turn loop antenna where the
    turns are reversed with respect to each other
  4. KL7AJ
    KL7AJ Ham Member QRZ Page
    Although transmit and receive gain and radiation pattern are reciprocal, the REQUIREMENTS aren't A very small loop, for example, can make an excellent low noise antenna, but the radiation resistance is extremely low, and does not make an efficient transmitting antenna.
    Sometimes having a sharp null in the pattern is very useful for a receiver antenna...either for direction finding or noise reduction, but it is seldom a good thing for a transmitting antenna.
    Certain antennas like the Beverage are very good receiving antennas, but are totally unsuitable tor transmitting.
    Hope this helps.
    Eric
  5. W0BTU
    W0BTU Ham Member QRZ Page
    Well said, Eric.
    I spent most of the evening working on and listening on my Beverage receiving antennas. I'm slowly putting together a web page about them at http://www.w0btu.com/Beverage_antennas.html.
  6. W5DXP
    W5DXP Ham Member QRZ Page
    The primary factor is the dynamic range of the receiver, e.g. being able to amplify the received by 70 dB or more, an advantage not shared by a transmitter. So as long as the signal to noise ratio doesn't decrease during receive, the efficiency of the receiving antenna doesn't much matter up to a point. A 0.1% efficient receive antenna usually works just fine for receiving.
  7. KB9MZ
    I appreciate the responses but are they not ignoring the fact that the antenna is resonant?
    A case in point. A foot cube box of wire is crambed full with wire that happened to be resonant with a 50 ohm impedance.
    If it was receiving S9 signals on top band what could happen to prevent reciprocity in transmit assuming that the radio is working correctly?
  8. KA4DPO
    If you had a box containing an electrically resonant length of wire and it showed 50 ohms at the feed point at it's resonant frequency then you should call the Pope because a miracle just happened. As far as reciprocity is concerned you wouldn't need to worry about that since the signal on the wire running in all directions inside the box would mostly cancel so I guess you would have a cheesy dummy load.
    There are a whole bunch of antenna books that can be very helpful in situations like these, I would be happy to recommend some if you like.
  9. KB9MZ
    To cut to the chase. It has been stated that you can cram a bunch of wire into a small space where the wire
    is at least a wavelength and is resonant at 50 ohm impedance. But the "fact" remains that it is still a short antenna!
    If this is really a "fact", and it is often stated on this newsgroup, what happened to the supposed reciprocity theorem? WHAT made it a " receive" antenna only
    The question comes about because of the fact I actually posses such a compressed antenna array for top band and I want to know what are the actual circumstances that could make it a "receive" antenna only?
  10. N1CZZ
    N1CZZ XML Subscriber QRZ Page
    This thread is good timing for me. I been thinking the last few days that I need to research received antennas a little more. Already here in Florida I am getting very high static/static crashes, as if it was summer. I have an antenna that works great on 160-40m, but with 10-20 over static crashes, it doesn't do me too much good.
