ad: AbAuRe-1
Please add FT8 mode
Discussion in 'Logbook User Forum' started by KG2C, Jul 2, 2017.
  1. KG2C
    KG2C Ham Member QRZ Page
    Could you please add the new FT8 mode to the list of available modes?
    It is a digital mode, similar to JT65 as far as standard exchange and signal reports.
    VE3FDZ and LW9DYQ like this.
  2. W1DQ
    QRZ adopts the latest revision of ADIF Specification protocol; see: www.adif.org
  3. W1AER
    W1AER Ham Member QRZ Page
    Would it be possible to add mode T10 to the list of available modes too? This is a mode available in the JTDX program.
  4. W1DQ
    www.adif.org controls what is listed. Logbook programs then adopt the latest revision for uniform ADIF file protocol,
  5. KG2C
    W1DQ, assuming what you say is correct, please explain this?
    It is looks possible to log FT8 if it is inserted through the API but not through the drop-down menu in the site's UI.
  6. W1DQ
  7. ON3MK
    ON3MK Ham Member QRZ Page
    I dont see FT8 in QRZ for my logs ?
  8. W1DQ
    As stated previously, FT8 is not yet listed in the latest revision of the ADIF specification. Hence for standardization, it is not listed in QRZ mode choices.
    Request this from ADIF officials.
  9. ON3MK
    ok thanks for the info all the best 73
    ON3MK Maurits
  10. N4TTN
    N4TTN Premium Subscriber QRZ Page
    Item 78 will add FT8
    The proposed ADIF 3.0.6 Specification 2017-07-15 is now ready:
    http://adif.org.uk/proposed/306/ADIF_306_annotated.htm
    http://adif.org.uk/proposed/306/ADIF_306_Resources_annotated.htm
    http://adif.org.uk/proposed/306/adx306.xsd
    http://adif.org.uk/proposed/306/adx306generic.xsd
    There's also a ZIP of the above files here in the adifdev Files area named:
    ADIF_306_proposed_2017_07_15.zip
    Items that have been included in the proposed 3.0.6:
    Item 20.1: Add constraints to applicable Number-type fields AGE, CQZ etc.
    Item 20.2: Add constraints to fields: ANT_AZ, ANT_EL
    Item 49: Add C4FM to modes
    Item 50: Enhance “Introduction” section
    Item 51: Add field names to the Table of Contents
    Item 52: Align DXCC entity names with ARRL’s list
    Item 54: Add YO DX HF Contest
    Item 55: Correct Primary Administrative Subdivision for Italy
    Item 56: Update Primary Administrative Subdivision for Chile
    Item 57: Add ARRL EME Contest
    Item 59: Add FSQCALL
    Item 60: Add My Antenna field
    Item 61: Add a REGION field to support WAE and CQ entities
    Item 62.1: Update Primary Administrative Subdivision for Country Code 5 (Aland Is.)
    Item 63: Add a DARC_DOK field
    Item 64: Update list of Alaska “Counties”
    Item 68: Minor corrections and changes
    Item 69: Add T10 mode
    Item 73: Remove Prefixes from Primary Administrative Subdivision table
    Item 74: Add "ADIF_" to the Sponsored Award Enumeration
    Item 75: Add a DXCC column to the ARRL Sections table
    Item 76: Add an External Links section
    Item 77: Add newer JT9 Submodes
    Item 78: Add FT8 mode
    73 de Graham G3ZOD
