Old 10 Meter RCI Radio Question
Discussion in 'General Technical Questions and Answers' started by KO0N, Nov 5, 2009.
  1. KO0N
    KO0N Ham Member QRZ Page
    I have a Ranger (Mirage) 2950, this radio does not like the cold. This radio resets itself to 28.000 Mhz or, will turn on and be stuck at 31.999 Mhz until I go to the "Manual" mode and tap the transmit button.
    CB Tricks says that there is a battery for the cmos in the CPU but, I do not see it; it does not seem to be accessable from the inside of the radio without removing the front panel from the display AFTER the display unit has been separated from the chassis.
    I must be missing something......
    I like this radio alot and, I am wondering if there is someone Trustworthy and reliable who has repaired RCI radios. I am looking for someone with knowledge of the quirks of these radios.
    My service monitor / scope crapped out so, I am kinda like a row boat with only one oar in the water.
    The CPU board in this radio is is the DPT295042z, the same boards are in the 2527, the RCI 2950, 2970 and, the RCi 2990. The CPU / PLL goes crazy and thre radio has to be reset to the desire operating frequency when powered back on.
    The is no visibile battery backup for the CPU ROM so, it seems to be erased every time it is powered or or off.
    this is the board
  2. W9GB
    Dallas/Maxim and other IC manufacturers are actually placing SuperCapacitors and/or batteries within the RAM or uProcessor die itself!! You would have to replace the uProcessor or RAM!!
    I have one here a fairly new RAM device that Dallas/Maxim sent me for testing -- replaces 3 separate parts and a lithium coin cell on the PC board (everybody wants a smaller device these days).
    Since the parts list and PC board layout X-ray does not show a battery -- that would be my first guess. Planned obsolescence by Ranger with a specially made uProcessor?? Cross-check the uProcessor numbers. Possible!
    w9gb
  3. KC4UMO
    KC4UMO Ham Member QRZ Page
    Greg may be right on that.
    I do know the EPT295043Z board has the coin sized battery mounted on the other side on the board. Right behind the CPU.
    It is not very hard to get to.
  4. AE1PT
    AE1PT Ham Member QRZ Page
    You do understand that RCI junk is intended for the CB/Freebander crowd?
  5. N9JRN
    N9JRN Ham Member QRZ Page
    A remark like that makes you sound like an idiot, The RCI-2950/70 radios are intended to be a 10 meter ham radio and a damned good one at that. I know it can be easily modded to go on CB but so can my IC-718, and your FT-2000, and his ts-2000, so get off it if you don't have a real answer don't post this (THATS CB ####),. Some of you people are real boneheads!!!:mad:
    And if you open the speaker side of the case, and look down the back side of the vertical board that the display board plugs into, the battery shoul be about in the middle of the board way down by the main board, it's a 3 volt lithium battery about the size of a quarter with the buzzer stuck to it with double sided tape.:)
    Hope this helps, Aaron
  6. AE1PT
    Oh please. They are garbage marketed to the freeband crowd that 10 meters is simply an excuse to try to elude the FCC. They are not intended for ham use, and a short Google search will confirm just what they are being used for.
    Easily modded my foot. Most shops that they are bought in already have the work done on delivery. Beware of accusing folks here of being an idiot...
  7. KC4RAN
    KC4RAN Ham Member QRZ Page
    What... you mean to tell me "real hams" don't shop at the local truck stop? They don't order their top-end radios from Copper?
    No way!?!
  8. N7ZZT
    N7ZZT Ham Member QRZ Page
    junk? for some of us on limited incomes, its about all we can afford (and mine si strictly 10 meter thank you very much). for a "junk" radio it has a very nice receive (not as good as say yaesu or kenwood, but in a pinch it works nicely).
    also, I hate to bring this to yur attention, but just about any amateur radio with 10 in it can be modified to work freeband/11 through the use of the mars/cap modifications built right in. so... your claim that its specifically marketed for the 11 meter/freeband crowd falls flat. I purchased mine at a local radio shop (HRO didn't have any in stock at the time) and I probably paid about $50.00 more than I should have, but, its mine and it woirks.
    anyway, calling a specific radio that is actually FCC type accepted for the US market as a freeband/11 meter radio when there are others specifically made for that market (and are highly illegal) is a farce. you want a freeband radio, try the cobra 148gtl-dx (24-30 Mhz with switchable banks) or the Thunder 2000fm (with 6 banks for 40 channels each plus FM mode) or a few others.... There are many others....
    I wish I had the 700-900 dollars for a kenwood or an icom or a yaesue, but i don't. so I went with what I could get. you don't like it? TOUGH!.
  9. N7ZZT
    funny, mine came from apollo communications and it was factory spec only. no mods. care to try that again?
  10. WB2WIK
    You might want to re-think that, because it's not true.
    The RCI2950 is absolutely on the FCC list of "banned radios" because they are absolutely not certificated for the United States:
    FCC LIST OF BANNED RADIOS
    COBRA - model: 200 GTL DX
    CONNEX - models: 3300, 3300 HP, 3300HP-ZX, 3300 PLUS, CX-3800, 4300 HP, 4300 HP 300, 4400, 4400 HP, 4600 Turbo, 4800 DXL, 4800 HPE, Deer Hunter, General Lee, General Washington
    GALAXY - models: 33HML, 44V, 45MP, 48T, 55, 55V, 66V, 73V, 77, 77HML, 88HL, 93T, 95T, 99V, 2517, 2527, 2547, Melaka, Saturn and Saturn Turbo
    GENERAL - General Jackson, Grant, Stonewall Jackson, Lee, Washington, A.P. Hill, Longstreet, Sherman
    MAGNUM - models: 257, 357DX, Alpha force, Delta Force, Mini, Omega Force,S3, S3RF, S6, S9,
    MIRAGE - models: 33HP, 44, 88, 99, 2950, 2950EX, 2970, 6600, 88H/L, 9900,
    NORTH STAR - models: NS-3000 and NS-9000
    PRESIDENT - models: Grant, J.F.K., Jackson, Lincoln, HR-2510 and HR-2600
    PRO STAR - model: 240
    RANGER / RCI - models: AR-3500, RCI-2900, RCI-2950, RCI-2950-DX, RCI-2970, RCI-2970-DX, RCI-2980-WX, RCI-2985-DX, RCI-2995-DX, RCI-6300, RCI-6300 Turbo, RCI-6300F-25, RCI-6300F-150, RCI-6900, RCI-6900 Turbo, RCI-6900F-25, RCI-6900F-150, RG-99, Voyage VR-9000
    STRYKER - model: 440
    SUPERSTAR - model: 121, 122, 36, 3700, 3900, 3900HP, 3900 American Spirit, 3900 HP G, 3900 Gold, 3900GHPA, 3900GHPM, 4800, Grant
    TEK - model: HR-3950
    UNIDEN - models: HR-2510 and HR-2600
    VIRAGE - model: 3300, 3300 HP, VX-38, VX-39
