ad: NI4L-2
NR22L mount help
Discussion in 'Mobile Radio Systems' started by K6DEA, Apr 9, 2012.
  1. K6DEA
    K6DEA Ham Member QRZ Page
    Just got my Diamond NR22L in today. I currently have a wilson 5000 roof mount and the antenna is holding up pretty good, but i don't know how long it will last. So, i am on the hunt for a custom mount or a 5" diameter washer as a backing plate for the inside of the roof. I found these but i dont know if its the right way to do this.http://bellsouthpwp.net/b/r/breedlove1/page28.html
    i DO NOT use mag mounts, and want it on the roof. so a hitch mount is not an option.
    Give me an idea what i can do. thank you.
  2. K6DEA
    This is pretty much what i have now as a mount system.
    http://www.hamradio.com/detail.cfm?pid=H0-003634
    it has a 3" washer on the bottom goes through a hole in the roof and a plastic washer and rubber washer on the outside of the so239/UHF mount. I am thinking that the 3" underneath is not enough under wind loads?
  3. K0BG
    What you really want is an honest-to-john NMO. They're not compatible with the Diamond NMO. Properly installed, they do not leak, even with the antenna removed.
    They advertise the NR22L are a "very high gain" 2 meter antenna—6 some dB as I recall. Well... It isn't any better than a Larsen NMO2/70BK. The reason is, they dB rating is is actually dBi, not dBd as it should be. Not only that, read the fine print about the "reference" antenna.
  4. K6DEA
    I know the debate between Larsen,Comtelco,Diamond,Comet etc etc..... i know.
    your off topic.
    I wanted a monoband for simplex and so far this aqntenna has outperformed all of my mobile antennas ON simplex within 5 mile tests. There is no way in the world a NMO will handle this antenna. i have done my research on DBD & DBI as-well as EIRP and ERP calculations.
    P.S I have 2 NMO mount's on the roof as well one is for 440, the other is for 220MHz.
  5. K0BG
    I my memory is correct, the antenna mounts on an SO239. An NMO is a much stronger mount, but you're probably correct, it needs more support. You're only recourse that I am aware of is the ballmount sold by Breedlove. It is ugly for sure, but on a adequate surface, will hold any current 2 meter antenna.
  6. W9GB
    The Diamond NR22L is a 96 inch antenna.
    Reminds me of Hustler collinear mobile antennas that WB2WIK used in 1970s
    http://www.universal-radio.com/catalog/hamantm/2210.html
    I have no information on your vehicle or this Wilson mount, BUT the NR22L will exert significant stress on that mount (due to its height) as you cruise down the highway.
    Common issue/problem for the radio installer with newer trucks, automobiles, and school buses (increasing usage of fiberglass and composite body parts). 2011 QRZ question.
    http://forums.qrz.com/archive/index.php/t-315204.html
    PCTel (MAXRAD, ANTENNA SPECIALISTS, BLUEWAVE, WISYS AND SPARCO WIRELESS brand names)
    sells a metal disk for installation under the antenna, to serve as a better attachment & ground plane for mobile antennas.
    http://www.antenna.com/apg_product_lines.cgi?id_num=12
    Part number: K332
    6-inch ground plane disk with .38" OD hole provides ground plane for fiberglass-bodied vehicles.
    http://www.antenna.com/apg_products.cgi?id_num=10999
    Usually used with 3/8 mounts, the hole can be enlarged for various mounts, as required (NMO, old A/S mount, SO-239)
    This item is usually "in stock" at better LMR dealers that do municipal & public safety radio installs.
    PCTEL, Inc.
    471 Brighton Drive
    Bloomingdale, IL 60108-3102
    Sales Toll Free: 1-800-323-9122
    Phone: 1-630-372-6800
    The Antenna Farm, Montana carries various mobile antenna parts
    http://www.theantennafarm.com/catal...4_1242&zenid=9417140012bfc4ba1aa395ad90688f4a
    The Antenna Farm
    PO Box 145
    Pray, MT 59065
ad: UR5CDXcom-1
