Need Rubber Gasket or Substitute For Johnson Ranger
Discussion in '"Boat Anchor" & Classic Equipment' started by KI4AX, Feb 19, 2017.
  1. KI4AX
    KI4AX Ham Member QRZ Page
    Hello to all:
    I am working on restoring/refurbishing a Johnson Viking Ranger. Due to a split in the original, I would like to replace the Rubber Gasket (D6 in the Assembly Manual) that is installed on the Escutcheon (D4) that the Dial Plate for the VFO (D5) is mounted in. The D6 Gasket is basically a small rubber U-Channel that measures 5 mm x 5 mm (outside dimensions) that slides over the edge of a piece of sheet metal.
    Does anyone know where to obtain: A) Another NOS D6 Gasket or B) Something that I can use to replace it with?
    Thanks,
    Dan KI4AX
  2. AC0TX
    AC0TX Subscriber QRZ Page
    McMaster is your go to source for hardware
    type window gasket
    or trim gasket
  3. WR2E
    WR2E Ham Member QRZ Page
    Or google rubber u channel
  4. WR2E
