Need help with D-104 PTT wiring
Discussion in 'Microphones, Speakers & Audio Processing' started by W0CMO, Apr 13, 2019.
Tags:
  1. W0CMO
    W0CMO Ham Member QRZ Page
    I have a D-104 with a TUG8 stand. Using it on a Kenwood TS-830S. It works great.
    However, I have to squeeze the PTT bar when I want to transmit. I don't have a manual for the mic so I don't know if there is a way to use the mic for VOX operation.
    Any suggestions would be appreciated.
    Thanks.
    Chuck
    WØCMO
  2. KD8DEY
    KD8DEY Ham Member QRZ Page
    the battery is connected/disconnected by the PTT switch. No power available from the radio. gonna go through a lot of batteries unless perhaps you find a nice quiet souece of replacement power. otherwise you would just slide the little ring up at the bottom of the PTT bar, & turn on Vox
    dunno if this would be quiet enough, but you could always add a little filtering..
    https://www.ebay.com/itm/9v-Battery...Mji8TvsL6w4Z4jA:sc:USPSFirstClass!42518!US!-1
    KA9JLM likes this.
  3. KA9JLM
    Normally you lock the PTT bar with the round ring and put the radio in VOX.
    Just like Bubba said.
    If that don't work, Or the ring is missing, Do what Bubba would do.
    K9ASE and KD8DEY like this.
  4. KD8DEY
    Duct tape....
    Ymmv
    KA9JLM likes this.
  5. KA9JLM
    A wire tie works too.
    Then you can slide it up and down, Without getting your fingers sticky.
  6. KD8DEY
    But you said to do what Bubba would do.
    I would be more likely to have Duct Tape handy.
    if it moves, but shouldn't, use Duct tape.
    If it doesn't move, but should, use WD40
    Cornbread usually doesn't come with wire ties....
    KA9JLM and AD5HR like this.
  7. W0CMO
    Yeah, that's my problem.
    KG7QJB likes this.
  8. W0CMO
    Yeah, that's my problem. When I squeeze the bar or slide the ring up, the xmtr keys. I would think that I could slide the ring up and then, with the VOX turned on, the xmtr would only transmit when I spoke. But it ain't working that way.
    Anybody got a suggestion - OR a schematic of the D104? There's got to be an easy solution to this.
  9. KA9JLM
    Disconnect pin #2 (PTT) on the TS-830 mic connector. (Or the wire on the D104 that goes to it.)
  10. K7TRF
    Here's the schematic for the active pre-amp version of the D-104:
    Here's the schematic for the older D-104 stand that lacks the mic pre-amp:
    I've seen some D-104 bases modified to include a PTT on/off switch so that you can do as Don suggests (break the PTT line to the rig) without completely losing PTT functionality.
    KA9JLM likes this.
