Need advice - guying collabsible mast
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KJ6EZQ, Mar 31, 2012.
  1. KJ6EZQ
    KJ6EZQ Ham Member QRZ Page
    I have a Buddipole antenna that is mounted on top of a painter's pole. The pole itself is strapped using hose clamps to a tall wooden stake that is driven into the ground (this part is fairly strong).
    We have been having much higher winds than I am used to from where I moved. Gusts up to 40 mph and constant 20 mph wind.
    I went with a semi-permanent installation because I'm renting and I don't want to put up a conspicuous mast all the time. In the winds the painter's pole sways badly, enough for it to reach down and touch the roof in strong winds (about a 45° angle).
    I decided to guy it and used some green contractor's string and turnbuckles. That actually worked quite well for when the mast was up, but when I pulled it down I ran into problems. Even though I wound the string up onto the turnbuckles tightly and pulled them tight to the hose clamps on the mast, the wind tore them off. They ended up so badly tangled in the bushes that I'll have to cut them off and start over.
    So I'm looking for a way to have the guy wires taught whether the pole is up or down. I'm open to other ideas for my situation. As it is I haven't been able to operate in 3 weeks. I'm also open to the idea of a stronger collapsible mast that can hold up to the winds.
    Thanks,
    --KJ6EZQ
    The Buddipole is a poor choice unless you only use one band all the time, since "band changing" involves major antenna adjustments.
    Do you use one band all the time? If so, which band?
    That will provide valuable information about what you can do as a better alternative.
  3. KJ6EZQ
    I'm happy with my choice of antenna so far. I try to use as many bands as I can. I have only made one contact on 40m, so I'm trying to do more of that lately, but I have been working all the bands I can.
  4. WB2WIK
    With the Buddipole design, to change bands you have to take the antenna down each time.
    Is that what you do?
  5. KJ6EZQ
    "Buy a different antenna" really isn't a discussion I want to get into right now, but I appreciate your opinion.
  6. KO6WB
    What other options do you have? Are there any trees nearby? How high is your roof and can you get up there? What type of operations do you have in mind?
    You could use the painters pole as a support for a single wire running vertical with the pole. Put down some radials (Even 10 foot radials help) and try to have as many radials as you can. You will get good results with 16 radials. A quarter wave vertical for 20 meters is just a little over 16 feet. With an antenna that short the performance on 40 meters will be okay but not great.
    Now about your guying problems, I haven't found anything cheap that would keep the guy lines taunt at all times. For instances, you could put each guy line on a winch and crank it to keep each line taunt. This would not be cheap and you have to make a method of mounting them that wouldn't cause them to pull out of the ground. Sorry, I'm not much of an engineer;). Keep looking around and thinking. You'll come up with a solution.
    Hope this helps
    Gary
  7. KJ6EZQ
    Thanks Gary,
    OK here are some additional details:
    I can access the peak of my neighbor's roof from mine (we're in a duplex unit) if I can find a taller ladder. The only accessible tree is not very tall, maybe 16 feet. Our back yard is not very large at all, so I could maybe manage 3 or four radials outward from the pole into the yard. As far as operations, mostly SSB and some digital.
    I was kind of thinking of something I can wind up the guy wires on maybe, but I'm not really sure where to start. The weather's pretty inclement lately so I don't see myself getting up on the roof any time soon.
  8. WD5JOY
    WD5JOY Ham Member QRZ Page
    As Gary points out a winch is one way - but expensive as heck as you would need one for each guy wire - not really an inexpensive way to go. You indicate your problems are when you "lower the painters pole" --- "contractor's string and turnbuckles. That actually worked quite well for when the mast was up, but when I pulled it down I ran into problems. Even though I wound the string up onto the turnbuckles tightly and pulled them tight to the hose clamps on the mast, the wind tore them off.
    I'm missing the problem when you lower the painters pole since you indicate you wound the string on the turnbuckles yet the wind tore them off. If the pole is down - the guys are loose are they not? Was it when the pole was UP that the wind did it's damage? I am reading incorrectly or your description is incomplete (to my OLD OLD brain cell). I'm not seeing how the guys can be tight when the pole is BOTH UP AND DOWN. I might be slow - so pardon my confusion.
    Also you noted - "The pole itself is strapped using hose clamps to a tall wooden stake that is driven into the ground (this part is fairly strong). However, you then note, " In the winds the painter's pole sways badly, enough for it to reach down and touch the roof in strong winds (about a 45° angle)." So, it is well attached at the BOTTOM, but when extended it "sways" -- yes? And again I come back to HOW can the guys be tight in the "up" and "down" pole position? It's not logical OR I am so confused it is time to stop.
    The limited use of the Buddipole as far as bands and changing bands sure is questionable too; but, you don't want a new antenna so how do you go about adjusting the antenna for different bands (the question was ask in another reply - but I don't believe you clarified).
    The only solution I see is to possibly guy in three directions .... then when you want to lower the pole instead of LOWERING It ---- loosen ONE guy wire and TILT IT SIDEWAYS and let it rest on the roof. Of course this would mean a hinge at the pole base instead of the secure attachment to the wooden "stake" that you originally described. A complicated situation to say the least; and it leads me to one last visit as to HOW can the guy wires be tight when the pole is UP and when it is DOWN? To ME - it can't be BOTH ways.
    I'm no help - but perhaps clarification about the install might help paint a clearer picture?
    Too bad you can't run a dipole install between your roof peak and that of your neighbors and dump the Buddipole.
    GO ahead --- toss rocks at the "old man"; senility covers my butt!:D
  9. KJ6EZQ
    OK sure, I can see how I can clarify. As far as the buddy pole goes, I bring it down and change tap positions and antenna arm lengths to change bands. It's really not any trouble to me as I don't change bands much except when I start to operate for the day.
    And you're right, it is not secure when it is both up and down, but what I had been doing is unhooking the turnbuckle in the down position to tie them up. The sway is not a problem when it's down. I reeled up the guy wires and tied them to the pole in what I thought was a secure position, but that's where they were ripped from.
    In the up position, with the guys, sway is not "as much" of a problem. Without them, it's impossible to operate in the winds we have been having.
    Maybe all I really need is a better way to secure the guy ropes when it is in down position.
  10. W6CD
    W6CD Ham Member QRZ Page
