My impoved mystery crystal set by G0CWA
Discussion in 'Homebrew and Kit Projects' started by G0CWA, May 9, 2012.
ad: K3QNTad-1
  1. G0CWA
    G0CWA Ham Member QRZ Page
    Hi as suggested by one of the forum members I have descided to present my home made radios as shown on http://makearadio.com/index.php The first of many I am going to show you is my version of the mystery crystal set with both improved sensitivity and selectivity.
    For a full write up and building instructions check http://makearadio.com/visitors/nick-mystery.php basically I have built a standard set but with an unusual twist to improve its perfomance.
    I hope you find this set worth your interest, or even having a go at yourself.
    I made the tuning scale by printing onto a printable mirrored cd and the tuning pointer is a small clock hand on the capacitor shaft
    Happy building and 73 for now Nick G0CWA
  2. AF6LJ
    That is very, very cool.
    Makes me want to build one.
  3. G0CWA
    Why not have a go Sue?
  4. AF6LJ
    It's been a project on the back burner for a while.
    An ex-coworker gave some galania (sorry spelling) from his families mine in Idaho.
    The plan has been to mount peaces of the crystal and build a crystal set.
  5. KO6WB
    Hi Nick, well another great posting and it got Sue's attention which is good.
    Sue needs to check out some of your other offerings like the mechanical audio amplifier using a carbon rod. That was really neat.
    Gary
  6. G0CWA
    Hi Sue
    OK about the galena, but if you do build one put a small signal diode, eg an 1N34A in as well to tune in the stations first before setting the crystal detector it makes things alot easier mine is hidden under the board all you need to do to bring it into play is put the whisker on the brass drawing pin. Also mount the galena pieces in woods metal or low melting point solder usually available from model making shops to solder white metal castings.
    No Gary it is not cheating to use a diode as well!
  7. KO6WB
    Okay Nick.....but with a 1N34A you don't get to play with the contact whisker. Some times you can get it to surpass the sensitivity of the 1N34A. Other times... well try again. There have been tricks with the diodes to get them more sensitive. Applying a bias voltage to them works well but that is definately cheating.
    Have fun
    Gary
  8. KH6AQ
    KH6AQ Ham Member QRZ Page
    I especially like your carbon beam amplifier.
  9. G0CWA
    From the nice posative comments I can see the carbon amp should be the next one! thanks. I'll post it in a few days. Thank you for all the comments.
  10. W4HAY
    W4HAY Ham Member QRZ Page
    Sue, if you'd like, I can drop a microwave diode in the mail to you. I've gotten much better results with them than the 1N34A.
    Neat idea! Now we wanna see the back of the set.
    I have a set with a Tuggle front end, and solenoid and spiderweb coils on sliding tracks. One of these days maybe I can get picture of it. I also have a 76 tube on a wooden base that connects to it as a grid leak detector.
