MPS2111 datasheet/info needed.
Discussion in 'Homebrew and Kit Projects' started by 4L4AGU, Apr 1, 2012.
ad: K3QNTad-1
  1. 4L4AGU
    4L4AGU Ham Member QRZ Page
    All I know that this is the bipolar transistor with built-in resistors. I'd like to know value of these resistors and hFE of transistor, so I can assemble an replacement.
  2. K7MEM
    K7MEM Ham Member QRZ Page
    This doesn't seem to be an easy part to find. I found the following information on http://an.hitchcock.org/repairfaq/sam/strbfaq.htm.
    "The MPS2111 (Q3) is a PNP transistor which has an internal resistor network in its base-emitter circuit. These devices are sometimes called 'digital transistors' since they can be used as simple buffers or inverters without additional input components. The values of the series and shunt resistors are both 10K for this particular part."
    At another place I found this circuit for a strobe light for a model rocket.
    Between the two you should have enough information to sub a transistor and a couple of 10K resistors.
  3. 4L4AGU
    Thanks, I've seen that schematics at another place "Kodak max flash", but it had no info about it, thanks!
  4. KA9JLM
    MPS2111 PNP with 10K resistors
    The Resistors are 10K
    Maybe this will help you.
    http://LCSC.Net/KA9JLM/MPS2111.pdf
    Have a great day.
