Motorola GM 350 Questions
Discussion in 'Mobile Radio Systems' started by K4EEZ, Jun 1, 2011.
  1. K4EEZ
    K4EEZ Ham Member QRZ Page
    Hello, I got hold of a used but in good shape Motorola GM 350 (Type MD334BB)
    This puppy has a LCD Screen and 11 push buttons on the front, a R.J 45 style mic jack, with the radio i also got mounting bracket and O.M.E Motorola hand Mic and mag mount base.
    my brother in the uk Bought it and sent it over to me as a gift as he knows i am into the ham radio hobby, Not knowing an awfull lot about this unit, i did a quick ggoggle search and found out that this radio (Depending on model?) can do V/UHF and 25 watts and have 128- Ch.
    But Furthe rading revrevils some small issues noted with ":confused: "
    from URL: http://www.mwc.co.uk/gm350.htm
    Motorola GM 350 Standard Features
    Internal Loudspeaker with 4 W audio power
    Private Line (CTCSS) and Digital Private Line
    Programmable Time Out Timer and
    Re-Key Timer
    Single Tone Encode for repeater access or limited selective calling
    Single Tone Decode for limited selective calling (128 ch display models)
    Programmable Power 5-25 W, set per channel from 2 programmable levels
    Choice of 12.5 kHz or 20/25 kHz models :confused:
    Ultra-Wide frequency range for maximum system flexibility
    Plug in modules for enhanced functionality
    Data mode (128 ch display models) :confused:
    I am really looking for someone who knows more about the Motorola radios than i do :eek:
    thank you for any help.
  2. K0BG
    I'd bet the programming software will cost you more than the transceiver did.
    GM350 aren't all that versatile for use on the amateur bands. Part of the issue is the channel spacing, which you noted. And the fact there is only one sub tone, which is a real drawback when you travel. Personally, they're a relic.
  3. K4EEZ
    Motorola GM350 Info Request.
    how about a model number etc would that help?
    theres a sticker on the bottom of the radio that has the following:
    TYPE: MD334BB
    S/N: *****2039
    Model: M08KHF4AA3AN
    Tanapa: EUD4845B
    I tried to look the serial number up on www.batlabs.com that you can punch in the serial number and it spits out the Model Number Decoding,, but can only find
    GM 300 or M120 :confused:
    Any Help?
  4. W9GB
  5. K4EEZ
    thank you Greg for the info :)
  6. K4EEZ
    OK just to give you guys an update, I dropped the radio of at my friends shop who deals with all sorts of 2-ways, we did a quick test on it and put it on the bench and tried veris of common rib/programs to try and pull data from the radio but non of them worked they all returned an error code or said the rib cable needs to be connected (it was plugged in), so this means back to square one...
    so let me ask the obvious, dose anyone have this program for programming the Motorolla GM350 or know someone that has it :confused:
    Thank you all
    73.
  7. K0BG
    Look up WØFM, and send him a private message.
