Mobile mini antenna coil 6 bands
Discussion in 'Ham Made Gear' started by KB9AIT, Apr 5, 2012.
  1. KB9AIT
    KB9AIT Premium Subscriber QRZ Page
    THE SILVER BULLET MINI Variable Tune Antenna Coil
    Operate 6 different HF Ham Bands with a single antenna for less than $30.00; just add any size 3/8 24 fine thread whip between 36 to 102 inch's. Made with the same quality and design as our Silver Bullet but at half the size. Operates from 6 meters to 30 meters depending on whip size. Built on a SCHD 40 PVC tubing and like our Silver Bullet, the coil core is groove for proper placement and spacing of the stainless steel coil wire. The coil easily tunes by simply sliding the tuning coupler up and down the coil until maximum noise is heard and lowest SWR. At just over 8 inches in total length, we made a 2 1/2 inch coil with over 14 feet of stainless steel coil wire on a 4 1/2 inch core. This small compact design reduces wind load, allows for trunk or hood mounting of your antenna and with a smaller whip this is an antenna installation even your YL can love. Easy to install the coil only requires and antenna whip that can be purchased at any radio outlet that sells 102 inch whips. No mechanical parts to break down. Use the Silver Bullet Mini for all applications like our full size Silver Bullet.
    For move information and a listing of frequency ranges you can expect using your coil see our webpage: www.wolfrivercoils.com
    See our You Tube video [ATThttp://youtu.be/Z3M9y12fNrA
