ad: hrd-2
Mixw problem
Discussion in 'Rig Control, Propagation, Cluster, & Other Softwar' started by Guest, Nov 20, 2002.
  1. Guest
    Guest Guest
    When operating mixw the macro button for xmit has to be clicked a second time before xmitting. The first click keys the rig, but then only stays on for a second. Then a second click is necessary to complete the xmission.
    This is getting irratating. This does not happen with other modes other than psk or when using digipan.
    swr is zero, alc is minimum
    Any info is appreciated.
  2. W5ALT
    W5ALT Ham Member QRZ Page
    If it only happens in that one mode, check your macro definitions for that mode. I once had a macro that ended with 2 RX commands and the software sat there waiting for a TX command so it could go back to RX mode as instructed. Also check that you haven't used the TX/RX toggle in the macro instead of TX or RX. That can lead to some oddball problems.
    If that doesn't turn up anything, send an email to the author. Nick has always replied to my emails fairly promptly.
ad: Amateur-1
