ad: Alphaant-1
microphone specs
Discussion in 'Microphones, Speakers & Audio Processing' started by KE5MUE, Apr 3, 2012.
ad: K3QNTad-1
  1. KE5MUE
    KE5MUE Ham Member QRZ Page
    I have a Kenwood 2000 and want to rig up myown boom mike. What specs do I need for choosing a mic?
    Caroidid(?) Dynamic Omnidirctional? Any comments?
  3. K6LCS
    K6LCS Subscriber QRZ Page
  4. WA7PRC
    WA7PRC Ham Member QRZ Page
    You need a low impedance microphone, which gives you a WIDE selection. Keep in mind that this is ham radio, not broadcast. You don't need to spend a king's ransom. Heil and others make works of art but, 99.9% of the time, the station on the other end isn't going to be able to tell the difference.
    When I use a boom-mounted microphone, I use a $20 RS #33-3038 (unidirectional, dynamic 600Ω) microphone. The specifications compare favorably with more expensive microphones. I've received many unsolicted comments, saying it "sounds as good as a Heil".
    I spent $50 on a low-rise long-reach boom (Hercules #MS540B). I use a floor flange and short section of pipe to secure it to the corner of the shelf above my wide operating table.
    But, most of the time, I use a headset (Heil ProSet Plus). No matter which way I turn my head, the microphone is ALWAYS in the right spot. Like a boom-mounted microphone, it leaves my hands free and (most importantly) doesn't occupy valuable operating desk real estate. Unlike a boom-mounted micrphone, there is no mounting to deal with, and it blocks out background noise (which can be good and/or bad).
    With both microphones, I use the Heil FS-2 footswitch (about $40) to keep my hands free to log & operate the rig. There's cheaper out there but the FS-2 is built like a tank and has two microswitches (one for the rig and one for an amplifier).
  5. AB3FL
    AB3FL Ham Member QRZ Page
    I use a MXL990 condenser mic and it sounds great. You will need some sort of preamp such as a Behringer VX2000 to provide the power for the mic and enough signal for your rig. I think I paid $50 for the mic from Musician's Friend
    Tom - AB3FL
