ad: w5yi
Microphone connector wiring for Radio Shack HTX-212
Discussion in 'Microphones, Speakers & Audio Processing' started by W9GB, Oct 28, 2011.
  1. W9GB
    I am new to the QRZ forums.
    I was trying to change the microphone connector (RJ 45) on my Radio Shack HTX-212, BUT I misplaced the old conector.
    I do not have the proper wire order (assignments, color).
    I may have to buy the wife a new radio if you can not help!
    Need help !
    Tom
    KC8OJY :(
  2. KD8DEY
    KD8DEY Subscriber QRZ Page
  3. W9GB
    No.
    I get a few newcomers to QRZ, that ask their questions directly to me via Private Message -- I do not answer these messages.
    Rather, I post their question in the QRZ Q&A forums where they belong.
    I believe that the Radio Shack HTX-212 was OEM manufactured by Kenwood.
    As I remember, it was based on the Kenwood TM 2x1 series of radios (221/231/241) -- of that period (mid-1990s).
    The Radio Shack used a 6-pin modular connector on this radio, while the Kenwood radios used the 8-pin Foster circular microphone connector.
    Manuals and part listing can be found on Radio Shack web site, under Support !
    CONSULT and READ the G4WPW Micorphone Connector web site for a PICTURE of 6-pin connector !
    6 pin modular connector
    pin 2 - BLACK (Ground for PTT and MIC)
    pin 5 - YELLOW (Microphone)
    pin 6 - RED (PTT)
    w9gb
  4. W0LPQ
    W0LPQ Ham Member QRZ Page
    8DEY ... so Greg has 11,698 posts ... big deal since I would bet that 11697 of them have good informaton. Greg is one of the most helpful guys on this site. So is Steve, WB2WIK and Glen, K9STH. It is pretty obvious you have not followed Greg with his wealth of info.
  5. WA7YLI
    WA7YLI Ham Member QRZ Page
    I have a RadioShack HTX242 and it has a 8 pin, not a 6 pin modular jack. All eight leads are used. I have sent RG4WPW corrected information to fix his website.
    Pinout follows:
    1 Tone
    2 Gnd (mic shield)
    3 Ck
    4 Con
    5 Mic
    6 PTT
    7 5V
    Data
    Larry WA7YLI
  6. WA7YLI
    Radioshack microphone pinout - HTX212/242 use 8 pin RJ 45
    Pinout follows:
    1 Tone
    2 Gnd (mic shield)
    3 Ck
    4 Con
    5 Mic
    6 PTT
    7 5V
    Data
    Larry WA7YLI
  7. WA7YLI
    Pinout follows:
    1 Tone (yellow)
    2 Gnd (mic shield)
    3 Ck (black)
    4 Con (green)
    5 Mic (white - center conductor of shielded wire)
    6 PTT (orange)
    7 5V (brown)
    8 Data (pink or red)
    Larry WA7YLI (801-971-7372)
  8. WA7YLI
    Forgot to mention.. you need to be careful about interpreting the pinout order. On the RadioShack, if you hold the new connector with the latch away from you so you are looking at the "flat side", with the connector pointed up (cable coming in from the bottom), pin 1 is on the left. Not everyone numbers them this way. I think this is consistent with the "Icom" numbering convention as listed on RG4WPW site.
    Pinout follows:
    1 Tone (yellow)
    2 Gnd (mic shield)
    3 Ck (black)
    4 Con (green)
    6 PTT (orange)
    7 5V (brown)
    FYI: I'm in the process of replacing my connector as well. Be sure you get the right RJ45 (stranded version, or you will have intermittent connections) they come in both varieties.
ad: Alphaant-1
