ad: Ebabel-1
MicroMatch MM-2
Discussion in 'General Technical Questions and Answers' started by W1FIT, Apr 19, 2013.
  1. W1FIT
    W1FIT Ham Member QRZ Page
    This is my first post and hope I'm in the right place. I have an MC Jones MM2 SWR/Power Meter and haven't a clue (or a manual) on how it works. It has a pot on the front but that's it. How I differentiate between coming and going is a mystery. I'm not even sure if the n and the out ports are identified properly since the back panel fits both ways.
    I was hoping to use it with my newly acquired NCX-3. I have a new license and have surrounded myself with old things (like me).
    Thanks for any help.
  2. W9GB
    Joe -
    M.C. Jones Electronics was based in Bristol, CT. ‚ÄčI believe Bendix Corp. acquired the company.
    Sounds like you have the coupler unit for this meter??
  3. K8JD
    K8JD Ham Member QRZ Page
    Using the SWR meter
    Most simple SWR meters work like this;
    Select forward on the function switch.
    Generate a low power carrier from your rig. (I hope you realize just keying a transceiver in SSB mode produces ZERO output)
    Set the pot for maximum on the meter scale.
    Switch to reflected on the function switch and read the SWR !
    Stop transmitting.
  4. K8JD
    The National Radio NCX3 was my first SSB rig, in the late 60's, and at $129 used, it was affordable for me.
    It was tricky to use , with no ALC to limit voice peaks and no CW offset to hear CW on the transmit frequency correctly.. Broad receiver like a barn door !
    I eventually had to build a mic audio compressor/peak limiter so I would not flat top the voice peaks and cause splatter.
    I had to borrow an oscilloscope to get it set properly.
  5. W1FIT
    What's puzzling is that there is no forward or reverse switch.
    Thanks for any suggestions.
  6. WB2WIK
    That is a bit weird, never saw the meter without the switch.
    I've had several Jones Micromatch units with separate meter boxes and couplers over the years and the meter always had a switch.
  7. K8JD
    So you have to unscrew the PL259 connectors going to the box and reverse them to go from fwd to ref power. That or install the switch.
  8. W1FIT
    Thanks to all. I've figured out that reversing the connectors would probably work but be no fun at all. I would be thrilled to install a switch if I knew where to connect. Any ideas or suggestion?
  9. WB2WIK
    That would be easy to answer if we knew more.
    The "plug" and wiring that interconnects the sampler with the meter: Is it 3-conductor, using a 3-conductor plug?
  10. W1FIT
    mm2-back.jpg OK, Thanks. Here is what I have. Shield is one end of pot. white wire is other end of pot. Shield goes to one side of meter as well, not marked for polarity. Middle (wiper) of pot goes to other side of meter, also unmarked. Picture included.
    If you think that this can be reversed, then this is not the garden variety meter movement, e.g. x no. of dc microamps.
    Again, thanks for help and insight.
