ad: vanity
Mic Wiring Codes Badly Needed for Kenwood MC-50 Microphone
Discussion in 'General Technical Questions and Answers' started by W9ASS, Aug 11, 2008.
  1. W9ASS
    W9ASS Ham Member QRZ Page
    Hello Gents,
    I am looking to find out which wire is which for a Kenwood MC-50 Desk Microphone. I have found schematics online, which could be helpful but in all reality I really need to find out which color is which. I have removed the 4-pin plug and found 4 wires: a shield, Red, Violet, and another one I cannot remember the color of at this time (yellow?)....I needed to find out which is PTT, transmit, audio, receive, etc..This would be of great value to me as I am looking to wire this up to a Non-Kenwood radio, and I have heard from several hams that these mics work well and are a budget version of the MD-1's that go for 100$+. I got mine for 30$....Any assistance would be greatly appreciated, thank you for your kindness....
  2. N8YX
    N8YX Ham Member QRZ Page
    I'll post the info when I get a look at the schematics...but..if you have the mic readily available you may want to remove the bottom of the unit and have a look at the wiring.
  3. W0LPQ
    W0LPQ Ham Member QRZ Page
  4. W9ASS
    Normally the G4WPW site is very good, but it does NOT have a color code, which is what I need.
  5. K4YDI
    K4YDI Ham Member QRZ Page
    MC-50 microphone
    Post valid e mail address please or do a google search on MC-50.
  6. W9GB
    You will find that the Japanese manufacturers have not been consistent in wire colors -- SO -- that approach is NOT 100% valid. How many times I have posted this comment?
    I think it is about time you learn how to use a DVM or VOM -- to answer that question,
    instead of just ordering up you room service questions here at QRZ Q&A.
    LEARN HOW TO FISH
    "Give a man a fish and he will eat for a day. Teach him how to fish and he will eat for a lifetime."
    Chinese Proverb
    A Focus on Self-Sufficiency -- and not welfare
    http://www.teachamantofish.org.uk/
    w9gb
  7. W0LPQ
    Agreed Greg, which is why I posted the G4 site. A DVM indeed would solve the issue.
    Or, as was suggested, google it. The MC-50.pdf has the color code, but as Greg suggested, they are not always the same.
  8. KM5FL
    KM5FL Ham Member QRZ Page
    There is a lesson to be learned here. Over time mic cables become worn out and get replaced. The wire color as it relates to pin out can get changed in the process, so "standard color code" goes out the window. The procedure I use when rewiring a microphone to be used on another radio is to determine which radio the mic is presently wired for. Sometimes an easy task, some time difficult.. Using the pin out for that radio, I determine which color wire is used for what circuit.. I make note of that and THEN I remove the plug.
    Here's a bit of information that will help you figure it out.. The audio lead (mic +) is usually the one that has the shield around it. This wire is usually white. That covers 1/2 of the wires in your mic. The 2 remaining wires are most probably the PTT control wires.. One of those could be a ground and the other is the PTT... My guess is (and that's just a GUESS) the shield and gnd were connected to the same terminal on the mic plug you removed, leaving one terminal unused..
    KM5FL
  9. W9ASS
    KM5FL,
    Thank you for the info, as well as the the previous posters. I have but 3 wires to utilise, and one wire is not attached. In a Yaesu 700 series/FT-ONE, I find that I only need 3 wires, to be connected to pins 6, 7 and 8. True, colors do change per radio and microphone, maybe this wasn't the best determining factor?
    I have since found the pinout correctly, and a plug will be on momentarily. Thanks.
  10. WA9SVD
    WA9SVD Ham Member QRZ Page
    In addition to the above information, once you determine the mic is working properly, keep a permanent copy of the way you wire the plug for future reference. It will save the trouble of asking again in a few years if you again change radios or want to use the mic on a radio other than an Yaesu. (HINT: You may be able to tape a note or diagram to the INSIDE of the mic base, so you won't lose the information,
