ad: NSIComm-1
Mic for TS-2000
Discussion in 'Microphones, Speakers & Audio Processing' started by N0FPE, May 17, 2005.
  1. N0FPE
    N0FPE Ham Member QRZ Page
    what is the best mic to use with a TS-2000 other than the stock hand mic?
    Thanks Dan
  2. W5LDA
    W5LDA Ham Member QRZ Page
    Dan
    I am using an mc-60 on my ts2000 with great audio reports. Was told by several people my ssb sounds like fm. I run with the audio set at 70% with the mic amp on
    kd5vsg
  3. KF0RT
    KF0RT Ham Member QRZ Page
    Dan - Assuming the TS-2000 is similar to the TS-570, I've had good luck with the MC-60 also. The amplifier in the MC-60 is somewhat succeptable to RF feedback (a problem here), so I run it without the amp.
    I've also run a non-amplified D-104, but not enough testing on that to form an opinion yet except to say that it does work and I've had no complaints. Again, this is on a TS-570SG, but the same Kenwood mics are used for both that and the 2000.
    MC-60's can be found on eBay and other places. I tried to buy one new late last year and ended up cancelling my order after a lengthy wait. The guy at Gigaparts told me that Kenwood was having problems getting one of the parts. Presumably they're back in stock by now.
    73, Rob
  4. AI4IJ
    AI4IJ Ham Member QRZ Page
    I'll put in a third plug for the MC-60 mic. I use the same settings as VSG. I consistently get excellent audio reports. I don't think you could go wrong with it.
    Of course, HRO, and others, were running specials where they included Heil Goldline mics with the TS-2000's. I imagine that someone will chime in with experience with those.
    Richard
    AI4IJ
  5. KF3EG
    KF3EG Ham Member QRZ Page
    MC 60 is they way to go, Heils make good door stops.
    Jim
  6. NZ3M
    NZ3M XML Subscriber QRZ Page
    I know three guys that use the Heil Goldline and they sound great. The 2000 has many features that can change the audio, wide, narrow, and bass settings etc.
    If you are really worried about how you sound, you should listen to yourself with headphones hooked to another reciever. Then you can taylor things to your liking.
    Dave
  7. KF0RT
    The 2000 doesn't even require a separate receiver to do this... Problem is, we're not always the best judge of our own audio, especially in real time. Something about listening to your own voice. Should be good enough to hear any problems, though.
    73, Rob
  8. N0FPE
    Thanks guys. I just picked the 2000. used but looks like new. and at 600 bucks less than new!!!! I think I will get a MC-60 as that seems to be the way to go!
    Thanks Again!!!
    Dan/NØFPE
  9. W9GB
    Dan -
    The MC-60 should work fine.  First, check to see if your MC-60 has batteries in its base (not powered by the radio) - this varies depending upon the radio the MC-60 is used with.
    ALSO - Double check the microphone plug wiring on ANY used microphone purchase - modifications (to work with other radios) are rarely documented by sellers.
    MODS.DK has the schematic and instruction manual originally shipped with this microphone.  This is will be very helpful for proper interfacing and operation.  Some of this information is also available at KENWOOD.NET
    http://www.mods.dk/view.php?ListManuals=kenwood
    MODS.DK also has MC-60 notes for addressing RFI issues and adoption to non-Kenwood radios (e.g. Icom, Yaesu).
    http://www.mods.dk/view.php?ModelId=389
    The Heil "GM' series microphone was provided "free" with new Kenwood TS2000 purchases about 18 to 24 months ago.
    http://www.heilsound.com/amateur/gm.htm
    You may wish to look at Heil Sound offerings - as well.
    http://www.heilsound.com/amateur/catalog.htm
    w9gb
  10. KC0W
    KC0W Premium Subscriber QRZ Page
    For best results run at least 1500 watts while monitoring yourself on the other radio. Exact freq of course. Tends to work best with real expensive rigs........Icom 7800, FT-1000D etc.
    Tom kcØw
