Metron Magnus MA1000B
Discussion in 'Amateur Radio Amplifiers' started by KD9NKJ, Aug 3, 2019.
  1. WR2E
    WR2E Ham Member QRZ Page
    No problem, just wanted to clarify!
    I don't think you mean 'in series', but rather in parallel, but be VERY CAREFUL! Many (perhaps MOST) power supplies can not be connected in parallel without damaging one or both of them. Make sure that the manufacturers directions specifically say that this can be done and follow the instructions carefully!
    Are you sure you need 100 Amps? and if so, 8 ga wire is probably not big enough.
    Indeed, you'd want parallel operation, not series operation, and make sure the power supplies are designed for that; some specifically are, most are not.
    If they have "remote sensing" terminals and instructions how to use them when using supplies in parallel, that should work.
  3. KD9NKJ
    KD9NKJ Ham Member QRZ Page
    I watched a YouTube video of the installation procedures, and I'm using the manufactures specs. My Elmer has walked me through the procedure on paper and has said that providing I do not have the wires over three feet in length, I should be fine. The manufacturer has indicated the same in their video.
  4. N8FVJ
    N8FVJ Ham Member QRZ Page
    If the power supplies output the same voltage, they should draw equal current. If not, adjust for exact same output voltage.
  5. WR2E
    I'd like to see the video.
    Can you post a link?
    I quickly found a link to video showing four in parallel but could not find a manufacturers website.
    Edit: never mind, found it.
  6. WR2E
    In theory that is true.
    But not all power supplies will survive being paralleled.
  7. KD2ACO
    I agree with that statement and raise you one. Most power supplies will self-destruct if they are not designed to run in parallel and/or are not hooked up properly.
    The best bet is to get 1 supply that will deliver the goods.
  8. WR2E
    From what I've seen about the Megawatt supplies this morning, it does appear that these can be safely paralleled.
    I'm sure that what FVJ said is true regarding these units, the output voltage must be carefully adjusted to be exactly the same otherwise one supply will 'hog' the current.
    Whether or not supplies will self destruct when connected in parallel depends on circuit design and MOST are not designed for such use.
    KD2ACO likes this.
  9. KD9NKJ
    Yes, same one I saw. Glad you found what you were looking for. I'm hoping they won't be so noisy with just two.
  10. WR2E
    Hopefully you got the newer ones with the quieter fans!
