MD-100 Modification
Discussion in 'Microphones, Speakers & Audio Processing' started by N6TRC, Apr 20, 2012.
  1. N6TRC
    N6TRC Guest
    I have a MD-100 that is trying to interface with a YAESU FT-840.
    The filters in the MD-100 requires 5.0 VDC that the FT-840 can't provide.
    So, I tried an external 5 VDC to the MD-100 but have failed to identify which trace must be cut so that the filters will operate.
    Has anyone done this mod before?
    YASEU has an application note for this, but they will not release it to the public.
    Any help or direct would be most appreciated. Thanks
    John, N6TRC jcalbano@att.net
  2. KB4QAA
    http://www.qsl.net/g4wpw/md100.html
    Do you have the spec sheet for the mic? This source says supply +5v on Pin 2 of the circular connector.
    I wouldn't go cutting any traces.
    Four approaches:
    1. Supply voltage thru pin2 of the circular connector and use the modular connector for connection to radio
    2. Add additional wiring to internal circuit board for battery/power supply
    3. Wire up circular connector for connection to radio, but with breakout wiring to power source
    4. Modify the radio to provide power thru existing pins.
