ad: GNOHF-1
MAC OS High Sierra, Digital Program
Discussion in 'OS: Mac OS' started by NL0H, May 8, 2019.
  1. K3DCW
    Where does your Signalink connect to on the 891? Doesn't it connect to the rtty/data jack on the back?
    Now, if you mean the USB port, did you install the drivers for the USB port? It won't appear until you've installed the SILabs drivers for macOS, available https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip. Make sure the USB cable that connects your FT891 to your computer plugged in, or else the install will fail. Once installed, you'll have to authorize the driver to load by going to the Security & Privacy Pane of System Preferences. Once authorized, then plug in your USB cable and you should be able to get it to work just fine.
    KA3BQE likes this.
  2. NL0H
    NL0H Ham Member QRZ Page
    Yes, it is connected to the rtty/data jack.
    I do not have anything connected to the USB port because I am not using CAT control.
  3. K3DCW
    Then, I'm not sure what you meant when you wrote "TX and RX is working now... but only if I have an audio cable from the radio to SignaLink for RX like before. I should be getting RX from the data port."
    If the SignaLink USB is connected to the 891's RTTY/DATA port, and if TX and RX is now working, what other "RX" do you expect that you should you be getting from the "data port"?
  4. KA3BQE
    KA3BQE Platinum Subscriber Platinum Subscriber Life Member QRZ Page
    Thank you so much for the link! I was really stumped on how to get the USB configured for the FT-891. Especially when Yaesu didn't post any drivers for the Mac. I was that close to dragging my Windows 10 laptop out to use instead of the Mac. I'm glad I didn't have to do that. Now I have WSJT-X and the fldigi/flrig combo working. Are there any other recommended software to use with the FT-891?
  5. K3DCW
    That's a very broad question. Check out the links on www.machamradio.com for links to all kinds of software.
    KA3BQE likes this.
