Lock me in, Scotty!
Discussion in 'Ham Radio Discussions' started by KL7AJ, Jan 5, 2013.
  1. KL7AJ
    So, how does one detect a radio signal >60 dB below the noise floor? Further, how does one do this without exotic digital signal processing?
    The traditional method for doing this is with the "Lock-In Amplifier" which is nothing more than a pair of direct conversion receivers operated in quadrature. The "binaural" I/Q receiver described a while back in QST is just such a beast...with one major difference.
    For such extreme low level signals, one must restrict the bandwidth, post-detection. Most lock-in methods work in the millihertz range....i.e, the "audio" bandwidth is .00i Hz or less.
    Of course, one can't receive very high data rates with such methods. So where does one use millihertz bandwidth receivers?
    At Hipas Observatory, we used the method extensively for detecting ELF signals generated by "pumping" the ionosphere with HF signals...the returns were generally in the 200 Hz range. We also used them for looking at Schumann resonances, which are naturally occurring ELF emanations excited by distant lightning strokes. Schumann resonance is at around 7-1/2 Hz, and is a good "test" signal for elf detection methods and equipment calibration.
    Lock-in methods will undoubtedly prove quite useful on our upcoming 630 meter allocation. It's an easy method to use and doesn't require any expensive hardware.
    Eric
  2. WB5WPA
    WB5WPA Ham Member QRZ Page
    Have you written any FORTRAN number-crunching apps that we can hack together under a GPL'd GUI so's we can have the same kinda fun?
    /mild humor
    Jim WB5WPA
  3. KL7AJ
    Actually, FORTRAN is the engine under Octave. The latest version of Octave also uses GPL graphics!
    Eric
  4. WB5WPA
    I was poking fun at WSPR and Joe T's work ... but I didn't know what was under the hood of Octave (nor had I ever looked!) ...
    Jim WB5WPA
  5. KL7AJ
    WSPR is indeed amazing, but there will always be a place for top end analog methods....or in addition to!
    Stanford Research Systems builds a Lock-In amplifier with DSP. :)
  6. WB5WPA
    Back to the question at hand ... have you cranked out any code that the greater (or lesser) amateur community can make some practical use of?
    Side Q: Are you close in any manner, way, shape or form to win/place/show on a Nobel prize (like Joe)?
    /all in jest don't ya know!
    Jim WB5WPA
  7. KL7AJ
    I don't think I'm near a Nobel Prize, but maybe someone who reads Radio Science for the Radio Amateur WILL be. Then I can take some credit. :)
  8. KL7AJ
    However...since you did ask (don't tell anyone)...I'm working (under the radar) with the FlexRadio folks on a pet project. I got to meet them at Dayton last year, and thought of a whole bunch of scientific applications for FlexRadios. They are ready made for a lot of the ideas I have. In fact, one of the fellers has a very similar background to mine....lots of ionospheric research and such.
    Eric
  9. WB5WPA
    Does the project involve more than just one pair of I-Q channels at a time?
  10. KL7AJ
    Yes it does....and the fact that you ask tells me you already know what I'm thinking. :) You are sworn to secrecy!
